Piston speed
I am starting to think about high reving engines... but the limiting factor is rods and pistons breaking. I read something that explained that it was piston speed that breaks these... they have to much stress because they go from 0 to over 100 in 4 inches twice every time the crank turns 1 time.
so how do you reduce the piston speed? I was thinking that a stroker of some type might do it.
Anybody on here know anything about this stuff Gkull? Ganey? Monty?
Thanks for the help guys... i hate it when i think, it ends up costing money in the end :jester
ZD
[Modified by ZD75blue, 9:50 AM 11/8/2001]
To find feet/minute, just multiply stroke times 2, multiply the result times rpm, and then divide the result of that by 12.
4" x 2 = 8
8 x 7000rpm=56,000 inches/minute
56,000/12=4667
A longer stroke will obviously increase piston speed, rpm remaining constant. Destroking will decrease piston soeed, rpm remianing constant, but it allows you to turn higher rpm before you reach 4500 feet/second.
Realistically, if you have good bottom end components - forged crank, rods, pistons, rod bolts, main caps, etc - the valvetrain is typically going to be your limiting factor, as mentioned before. As rpm increases, you must increase valve spring pressure, use lighter, more expensive components (titanium valves and retainers, shaft mounted rockers, etc).
Also, remember that as rpm goes up reliability and durability go down in the long run. For the street, and even some levels of drag racing, super high rpms are unnecessary. For reliability/durability purposes, it is generally better to increase displacement, rather than increase rpm, in order to increase power.
Anything else about this that i need to know?
ZD
Monty is right about C.I. the bigger the motor the less rpm required to make a given power level. So I always recommend 3.875 strokers to get 393-396 ci out of 350 blocks.
That is mainly my goal, and if I decide to use nitrous i can crank it up to 6,000 rpm without blinking an eye.
Thanks for the help and making me think about beefing up what I have got as apposed to going all out race style motor.
ZD :cheers:
For some of my ramblings on a similar related subject matter, check out:
http://forums.corvetteforum.com/zerothread?id=172555
I couldn't help but run my current engine configuration through the formula's you quoted for peak torque @ 2000 feet/min and peak hp @ 2800 feet/min, I'm sure all the other gearheads did the same thing;).
In my situation, peak torque and peak volumetric efficiency, both of which are actuals from a Superflow engine dyno, peak torque occurs at 5100rpm and peak horsepower at 6800rpm.
Using your formula: (stroke * rpm)/6 =
(4 * 5100)/6 = 3400 feet/min @ peak torque (97.5 V/E)
(4 * 6800)/6 = 4533 feet/min @ peak horsepower (95.5 V/E)
Thanks for the help with this... peak torque/ peak horsepower
:crazy: i just want it under my right foot :jester
Thanks for the link
and lars i dont have insomnia but would like to read the fuel milage paper.
Talk to you guys later, after i finsih under standing this auto math book... cross refrensing with power sevrets by smokey and horsepower book "how to make horsepower with chevy engines" i get a little confused, but in the end i might just understand enough to build one a these things
ZD :cheers:
[Modified by ZD75blue, 10:00 AM 11/9/2001]
