tristan, I don't know if these pics will help, but they are from my early 69 and taken several years ago. There are some small brackets that hold the grille in place, check that you have them.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[QUOTE=Red 69;1561756408]tristan, I don't know if these pics will help, but they are from my early 69 and taken several years ago. There are some small brackets that hold the grille in place, check that you have them.
The tab below your light is not used either.
Out comes the Dremel and off with the tabs.
I will keep the top tab above the light untill someone confirms they do not use it as well, so if you have a picture of just above your light it would help.
