78 air conditioning problem... overheating
Old Sep 2, 2007 | 08:52 PM
C6Manny's Avatar
C6Manny
Default 78 air conditioning problem... overheating
When i use the air conditioning on my 78 l82 on the highway, the car begins to overheat. It works fine at low speeds with the AC on, but when i get to about 70+mph, the temp gauge begins to go up. Does anyone know what may be causing this problem?
Old Sep 2, 2007 | 09:09 PM
Durango_Boy's Avatar
Durango_Boy
Your fan clutch may need replacing. As the clutch gets older they seep and stop locking up at high temps.
Try this:
When the engine is running and hot, pop the hood and watch the fan. Turn the engine off and count how many times the fan spins once it's off.
If it seems to spin freely it's gonna need a new one. If it stops within a turn or two then that may not be the problem.
Old Sep 2, 2007 | 09:14 PM
C6Manny's Avatar
C6Manny
Try this:
If this was the case, wouldnt the car be overheating at low speeds as well?
Old Sep 2, 2007 | 09:36 PM
rihwoods's Avatar
rihwoods
My 78 L-82 ran at higher temps using A/C at hwy speeds...in my case,my radiator had lost efficiency due to lower tube clogging...if you hear your fan engaging at lower speeds,the clutch is probably ok as most dis-engage at highway speeds anyway...
You might try a good flush of your system and clean your radiator surface...some other simple things to check are radiator seals, front air dam,etc..then go from there...
What temps were you experiencing ?
My cure was a new Dewitts Alum Radiator...temps do not go over 200 F at hwy speeds in 100 F ambient air with A/C on...
Rich
To 78 air conditioning problem... overheating
