Vortec question
Old Sep 3, 2007 | 07:34 AM
couperdecar's Avatar
couperdecar
Default Vortec question
Opinions needed. I bought a new set of Vortecs for my L48 from my local "head rebuilder"
My cam has .454 lift. He says stock Vortecs will handle this. Some articles I've read say yes , some no. They all can't be right ! Anyone running stock Vortecs with this lift ? Should I take the heads back and tell him to set it up for .500 lift ?
I hate spending $ if I don't need to - who doesn't ?
Old Sep 3, 2007 | 09:22 AM
Durango_Boy's Avatar
Durango_Boy
Call a different machine shop and see if they can be checked for lift. If they can't, have them do the work. If yes, you may owe them $20 for their time and you're all good.
Old Sep 3, 2007 | 09:27 AM
Serge144's Avatar
Serge144
I run Comp Cams XE256H-10 which has .454 lift with no problems. I have new Vortec heads from GM Performance.
Old Sep 3, 2007 | 09:33 AM
stingr69's Avatar
stingr69
Have the shop pop off the retainer and spring. Reassemble without the spring. Measure the clearance from the bottom of the retainer (at the valve stem) and the top of the valve guide/seal. You have to have enough clearance for the cam lift at that point. MUCH easier to check this before you assemble.
-Mark.
Old Sep 3, 2007 | 09:59 AM
Glensgages's Avatar
Glensgages
http://paceperformance.com/index.asp...D&ProdID=24756
12558060 - GM Performance Parts Small Block Chevy Cast Iron Vortec Cylinder Head - Complete 12558060
64cc Chamber, 170cc Intake Runner, 1.94 Intake, 1.50" Exhaust - Complete - For Use With Cam's Up To .480" Lift
Old Sep 3, 2007 | 10:26 AM
my mach 5's Avatar
my mach 5
The confusion comes from what Pace states as noted above and what SDPC has on their site:
http://www.sdparts.com/product/12558...Assembled.aspx
Old Sep 3, 2007 | 10:31 AM
Glensgages's Avatar
Glensgages
A friend of mine, Forum-member 80crabvette, recently got vortecs from SDP, but only after I encouraged him to get the upgraded heads, with valve-springs good for .525"-lift.
The '07 GMPP catalog, for whatever that is worth, states that standard vortec heads under the above part-number, are good for .475"-lift.
Old Sep 3, 2007 | 10:43 AM
tabbruzz's Avatar
tabbruzz
I have the votecs with a cam that has a 454 lift. I do have upgraded springs though...
Old Sep 3, 2007 | 10:45 AM
my mach 5's Avatar
my mach 5
JEGS says the same thing - .475. I know the 330 HO GMPP crate engine has a dual pattern cam in it with over .450 lift on the exhaust side. I would tend to follow GM's site as you noted.
The furstrating part is the variance on the lift numbers depending upon who's site you read.
To Vortec question
