blowproof bellhousing
Old Sep 3, 2007 | 02:39 PM
Belgian1979vette's Avatar
Belgian1979vette
Default blowproof bellhousing
Any recommendations on a blowproof bellhousing with block saver plate ? Partnumbes and what additional parts are needed.
Old Sep 3, 2007 | 02:43 PM
1fastC3's Avatar
1fastC3
lakewood http://store.summitracing.com/egnsea...=KeywordSearch and mcleod http://store.summitracing.com/egnsea...115+4294851526
Old Sep 3, 2007 | 02:57 PM
VetteThunder1's Avatar
VetteThunder1
I would recommend Lakewood.
This will probably fit your engine,
http://store.summitracing.com/partde...5&autoview=sku
Their stuff is SFI approved and also SCCA or NHRA required on some classes. Not sure what the sanctioning bodies are in the EU but if you are in a club or race at all the governing body will have the requirements for this. If you don't race or what ever, then the NHRA or SCCA have good guidelines for safety requirements.
Old Sep 3, 2007 | 03:13 PM
Belgian1979vette
Its not for anykind of racing. It is just a precaution i'm taking, since i will be spinning my engine at high rpm.
As far as I can see these don't have a block saver plate. Is that correct ?
Old Sep 3, 2007 | 03:24 PM
VetteThunder1
The Lakewood bell housings can be ordered with the block saver plate but it is a separate item, you also need to get the dowel pins as well. Talk to the tech support people at summit they should be able to get you set up.
Old Sep 3, 2007 | 03:35 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I would go with McLeod.http://cgi.ebay.com/ebaymotors/McLeo...QQcmdZViewItem
Old Sep 3, 2007 | 08:05 PM
gkull's Avatar
gkull
I have the lakewood BP and block saver. You also need the Long dowel pins and long GM fork stud.
The bottom of the bell hangs really low. I ground off more than a 1/4 inch. A smart person would use a plasma cutter and take off the lower edge. It is painted with a red powder coating that requires sanding the paint off the back circle to fit the tranny in smoother.
Old Sep 3, 2007 | 10:28 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Originally Posted by 63mako
Go McLeod You will thank us for it.
Old Sep 3, 2007 | 11:26 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The bottom of the bell hangs really low. I ground off more than a 1/4 inch. A smart person would use a plasma cutter and take off the lower edge...
Before I went to stiffer springs all around, I ground about 1/4" off of my 1st Lakewood, too.
Oh, you mean on purpose.
Old Sep 4, 2007 | 12:15 AM
gkull's Avatar
gkull
The bell is such tough steel that it took a long time to grind it. If it every whacked an ground object you would be in deep ****!
Old Sep 4, 2007 | 02:25 AM
Belgian1979vette
Does the fork somehow hit the firewall with it ?
Old Sep 4, 2007 | 08:14 AM
Gordonm's Avatar
Gordonm
Sawzall or put it up on a vertical band saw. It will take the bottom or whatever else you need removed off in a minute.
Old Sep 4, 2007 | 12:17 PM
jackson's Avatar
jackson
McLeod usually aligns better than LW. www.speedwaymotors.com 1-800-979-0122 offers NEW BH w/ plate for $250 ... looks like McLeod to me ... ask em.
Old Sep 4, 2007 | 02:59 PM
USALT1's Avatar
USALT1
You have to use a Corvette specific clutch fork, the standard chevy fork does not have enough bend to clear the firewall. Also, you can buy adjustable clutch ball-studs.
Old Sep 4, 2007 | 05:02 PM
glenn64vette's Avatar
glenn64vette
McLeod does align very well.
Old Sep 5, 2007 | 03:28 PM
Belgian1979vette
Its a macload... can't believe the price...Thanks
Old Sep 6, 2007 | 05:03 PM
jackson's Avatar
jackson
You're welcome ... Speedway's may have TWO starter pockets ... not a problem if you have room on left. BTW, I do accept gratuities ... a shot of warm kirschwasser would be great!
Old Sep 7, 2007 | 02:13 AM
Belgian1979vette
To blowproof bellhousing
