TPI woes almost gone (Long?)
Old Sep 3, 2007 | 04:54 PM
bruced267's Avatar
bruced267
Default TPI woes almost gone (Long?)
Well guys after almost a year of siiting I finally have it running and driving, much better than before I might add. I had a real bad hunting idle and a bad rich condition. I found that minimum idle was never achieved so the IAC was trying to do all the work!! I have now fixed the problem(s) I was after and I have a few new one?? I cant seem to fix the idle (too HIGH) coming to a stop or light, if I have time or wait it will come down to where it should be but down shifting at 2K is a little to high for me! Whats causing the delayed idle down? Think the IAC is weak or am I missing something else? Also how can I determine a lean condition on a TPI car? I have a backfire @ the 1/2 shift @ wot. Im running the stock FPR cap with 29lb injs, I have about 40/42 lbs of fuel (no vac) should I try the adj cap or what? Any help would be great
