Squeak Squeak
Old Sep 4, 2007 | 07:59 AM
captainmorgan's Avatar
captainmorgan
Default Squeak Squeak
I replaced the upper and lower bushings in the front control arms with poly bushings from VB&P. Now I have an annoying squeak when going over bumps. The instructions tell you to cut the steel sleeves to fit. There is no gap between the sleeve and the bushing after torquing the bolts down after installing them on the car. Did I cut them too much? How do I stop the squeaking?
Old Sep 4, 2007 | 09:21 AM
wartosh's Avatar
wartosh
77 with the same problem. Spray once a week with Silicone works
Old Sep 4, 2007 | 09:25 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When you got the bushing kit did it come with grease? Usually they have a pack of really heavy grease that is supposed to grease the bushings to prevent the squeak.
Old Sep 4, 2007 | 09:27 AM
captainmorgan
It did come with grease and I used it per the instructions.
Old Sep 4, 2007 | 10:28 AM
BerniesVette's Avatar
BerniesVette
Thats why I stayed with the rubber bushings. Some ply bushings have a lubricant impregnated in them to help with the squeeking.
Bernie
Old Sep 4, 2007 | 10:52 AM
captainmorgan
Bernie
VB&P claims that their bushings have "graphite-injected".
Old Sep 4, 2007 | 01:09 PM
BerniesVette
Try the silicone spray and see if it helps. I know a lot of guys that can't get rid of squeeks from the poly bushings.
Bernie
Old Sep 4, 2007 | 06:20 PM
captainmorgan
I will try the silicone spray but my engine is somewhat detailed and I hope it does not make a mess of things.
Old Sep 4, 2007 | 06:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Whatever they came with, the best thing you can lube poly bushings with is a marine or synthetic grease that resists wash out. That squeaking is the poly binding, so it needs to be addressed for reasons beyond being an annoyance. Grease all "bearing surfaces".
Old Sep 4, 2007 | 08:48 PM
Red70vette's Avatar
Red70vette
Call VBP and tell them of the problem. Everyone says poly bushings squeak. See what they say, you know they have heard this before.
Then buy rubber bushings. The rubber ones in my car lasted 37 years I figured that was long enough so I replaced them with rubber again. If I still have the car in 30 years I will replace them with rubber again.
Old Sep 4, 2007 | 08:52 PM
captainmorgan
I sent them an email earlier and Pattie replied, saying she passed it on to tech support. I'm waiting for a reply.
Old Sep 4, 2007 | 10:00 PM
TheSkunkWorks
For anyone who desires to push the capabilities of a shark on modern tires, the rubber bushings will deflect considerably, causing all sorts of unpredictable suspension dynamics.
The squeak can be solved...
Old Sep 4, 2007 | 10:47 PM
RIJVETTES's Avatar
RIJVETTES
I would be cautious about installing poly bushings just because of all the advertising and claimed performance benefits. I put polys in the rear control arms of my C4, and noticed no change except frequent squeak in cold weather. I recently installed poly motor mounts in my C3, and I love them- more vibration from the new engine lets me feel it. So be selective- modern rubber can be really good and last 30 years with no noise. Ask the OEM's. But if you only care about a stiff suspension for performance driving, then poly will get you there.
Old Sep 4, 2007 | 11:13 PM
bertmeister's Avatar
bertmeister
I used Sta-lube multi purpose marine grease by CRC for all my poly bushings and have no noises from them.
Old Sep 5, 2007 | 02:11 AM
Belgian1979vette's Avatar
Belgian1979vette
The reason why i'm going to remove them and install metal bushings
Old Sep 5, 2007 | 07:32 AM
72 LT1's Avatar
72 LT1
I'm using VB&P's poly bushings and have no squeaks. Are you sure you didn't trim the metal sleeve too short? If so, the poly bushing could now be "pinched" and no amount of grease/lube will cure the squeak for long. I beleive VB&P recommends the sleeve be .040 longer than the bushing, giving you .020 clearance per side. I could be wrong on the clearance #'s, its been awhile since I did mine. A call to Pattie would get you the clearance specs. Good luck
Old Sep 5, 2007 | 08:06 AM
captainmorgan
That is what I think I did on the top bushings. I trimmed them and everything was fine until I torqued them down. Now I do not have any gap between the washer and the bushing.
Old Sep 5, 2007 | 02:30 PM
captainmorgan
I just received an email from Pattie at VBP. Looks like I was the cause of the problem. I trimmed too much off of the inner sleeves just as I suspected.
Pattie is sending me some new sleeves at no charge. VBP is the best in the business. They will continue to be my number one source for parts.
Old Sep 5, 2007 | 03:05 PM
TheSkunkWorks
We've all come out looking like this before...
BTW, for anyone who doesn't already know, Pattie rocks!
To Squeak Squeak
