cs 144 alternator
Old Sep 6, 2007 | 01:56 PM
TPI BOY's Avatar
TPI BOY
Originally Posted by Sully1882
the 93-96 impala one bolted right in... no bracket changes and no clocking needed.... all i had to get was the little plug adapter from ecklers for a SI to CS. It is easy and a huge improvement...
Sully
where did you get your plug adapter
Old Sep 6, 2007 | 09:17 PM
Sully1882's Avatar
Sully1882
Default plug adaptor
these are availiable from ecklers and im sure many other vendors like Zip and Corvette central too
Old Sep 6, 2007 | 09:26 PM
Durango_Boy's Avatar
Durango_Boy
I got mine at Autozone, but it's not an adapter, it's just a CS plug that you have to splice into your factory harness. This is the diagram to follow when doing that.
Old Sep 7, 2007 | 01:17 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If you want to keep the SI plug, there are plug adapters available. Otherwise, it's just as easy to splice a CS plug onto the old wiring harness in place of the old SI plug.
