Flasher / Flashers????
Old Sep 7, 2007 | 10:26 AM
kayosnes's Avatar
kayosnes
Default Flasher / Flashers????
My turn signal stopped to work today. And i am guessing it is the turn signal flasher. But where is that located.
I see there are one flasher in the rear compartment. And there are also one on the fuse box. Why do i have sevral flasher on my car??? And where is my turn signal flasher????
Old Sep 7, 2007 | 10:28 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Turn signal flasher is under passenger side dash near the kick panel
never heard of one inthe rear of the car
Old Sep 7, 2007 | 10:33 AM
...Roger...'s Avatar
...Roger...
The one in the rear is for the alarm.
Old Sep 7, 2007 | 10:38 AM
sweethence's Avatar
sweethence
Ahhh, no alarm on the 68
Got it
Old Sep 7, 2007 | 10:39 AM
Hadez's Avatar
Hadez
I recently replaced my old what appeared to be original flasher and honestly miss the character of the long slower flashes vs. my new flasher flashes just like a new car...and now the car has lost some character.
Old Sep 7, 2007 | 11:43 AM
kayosnes's Avatar
kayosnes
Okey. So the flasher in the rear is for the alarm.
The flasher for the turn signal should be on the passenger side, dash area.
What are the flasher on the fuse box used for??? What looks like a flasher?
I am not using the alarm on my car. can i use the flasher for the alarm, on my turn signal? Are they the same type?
Old Sep 7, 2007 | 12:30 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Emergency four-ways.
Old Sep 7, 2007 | 01:25 PM
...Roger...
Yes you can use the flasher from the alarm on your signals or temporarily use the one from the 4 way.Yes they are pretty much the same.I think the turn signal used to be lighter duty and if used in the 4 way used to flash too fast but I dont think they make one that light anymore.Most are heavy duty and seem to cover a wider range of lights on the circuit.
Old Sep 7, 2007 | 01:41 PM
kayosnes's Avatar
kayosnes
Thanks for the info. Always good info in here
Old Sep 7, 2007 | 03:14 PM
Garrett1972's Avatar
Garrett1972
You might want to check if you have a burned out bulb first. The flashers were selected to flash with a certain amount of current flowing through them, and if a blinker bulb burns out they stop flashing. The remaining good bulb just lights up.
Old Sep 7, 2007 | 03:36 PM
kayosnes's Avatar
kayosnes
All bulbs are ok. Already checked that. so then i tought the most probably cause is the flasher.
Could it be anything else?
Old Sep 7, 2007 | 05:45 PM
Garrett1972
When you hit the turn signal, do the blinkers light up, and not flash?
Bad flasher.
Don't light at all?
It's might be something else.
Old Sep 7, 2007 | 09:13 PM
kayosnes's Avatar
kayosnes
Bad flasher.
Don't light at all?
On my car the "blinkers" are on the whole time. And then starts to flash when i hit the turn signal. Is that not the normal on every corvette??
As it is now, they are youst on all the time. So that make me conclud that it was the flasher. But it might youst be that i hope it is the flasher. Since that is what will be the most easy fix.
Old Sep 10, 2007 | 04:30 PM
kayosnes's Avatar
kayosnes
problem solved. used the flasher for the alarm. Function perfect. it also have the same slow flashing speed.
To Flasher / Flashers????
