You may find this link usefull. I used MSD'a universal wire kit and custom cut them to length. Because I dont have vise to use with the 'block' style crimper that comes with the wires I had to buy and expensive Moroso crimper.
Thanks, I saw that one in the archives already. It helped a little. I'm not looking for a AIM install though. Just burn free wire routing without having to install heat sheilds and wrap. I have hooker side pipe headers too.
The bend of the header is so close to the plug boot it melted it to the point its missing on the # 2 cyl.
I though there was a discussion in the past about this and guys said the short accel plug and the premade "such&such" wires routed under the headers were the way to go. I'll keep looking in the archives..
These are MSD 8.5mm superconductors. I had that same wire burn and others get toasty so put em all in a sock.
Cool thanks! I bought a 2 pack of those socks too but I see were I fuged up. I ran my #2 wire behind the #2 header pipe where its tighter. I see you ran yours to the plug from the front.
Guess I ruined that wires set
I'll order something new I guess. I just hate making plug wires...
This routing is working so far.
Also Ive heard, accel shorty Plugs is an alternative, but I havent had to go that route.
I just bought all new plugs with the wires so I don't want to **** that 35bucks away too. I'll pass on those plug for now. I just ordered some premade Moroso ultra 40 wires, should be delivered tomorrow.
I'm going to go with the under header routing. I didn't like how my last set was on top of the covers. It just looked too "busy" and interfered with the nice factory aluminum valve covers and checking the oil.
I have a set up similar to the one above. MSD wires are supposed to be able to handle a lot of heat. My pertronix wires couldn't handle being so close to my Hooker Headers (they were starting to fail). The MSD ones were $80, but I was annoyed that they wanted me to "make" the coil wire. I didn't want to do any more work after finishing my engine swap, so I used my old coil wire and it works just fine.
Well here those wires were on B/O so I cancelled. Thats cool cause I found exactly what I wanted- cheaper and IN STOCK.
I re ordered the MSD #31763. Already made, HEI 8.5 super conductors, in black, under header routing. $80.20 +s/h.
