Afterfiring, tuning, Carb/Timing Gurus?
Old Sep 9, 2007 | 05:57 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default Afterfiring, tuning, Carb/Timing Gurus?
I have just recently gotten my 78 back out on the road after sitting just due to lack of time to drive it and am noticing a few problems. When cruising at part throttle, I am getting afterfiring in the exhaust. I know this is a rich condition problem, but am unsure of where to start adjusting. I have a regular o2 sensor (not wideband) and guage in the car, can I use this to get anywhere near the proper settings, or do I have to have a wideband? Also, could this be an indicator of a cam going flat? My cam/engine have about 4000 miles on them so far. I am not getting any loud noises from the valvetrain, but the car does accelerate choppy sometimes like it isnt firing on all 8. I also have a somewhat surging idle. I have the summit house brand K1103 cam/lifters and 882 casting heads with 2.02/1.6 valves and flat top pistons. Otherwise the engine is basically stock. What time of vaccum numbers should I have at idle with this cam?
Any help will be greatly appreciated. Pictures added!
Chris
Old Sep 9, 2007 | 06:18 PM
dannyman's Avatar
dannyman
Not sure what vacuum you should have but it sounds as if you have a problem with firing on one or more cylinders. Check all ignition wires, condition of ignition system (cap for cracking, etc.) and I would pull all spark plugs and read their condition.
Sometimes when we troubleshoot we suspect major components instead of the basics. How long have you been considering upgrading the valvetrain components?
Old Sep 9, 2007 | 06:34 PM
BigBlockk's Avatar
BigBlockk
Chris
Surging is a lean condition.
Stumbling acceleration is a lean condition.
Popping in the exhaust is a lean condition.
If this engine was rebuilt to have better performance it will have better volumetric efficiency. This will tend to lean out the mixture. The '78's were lean to begin with for emission purposes. If it's the stock carburetor it will be even leaner. Start tuning.
BigBlockk
Later.....
Old Sep 9, 2007 | 06:42 PM
St. Jude Donor '09
BigBlockk
Later.....
None of the emissions equipment are still on this one as its no longer required to pass since it sees less than 1000k miles a year on road. I was attacking this as a "too rich" condition basically because if I am running this car in the garage, it will make your eyes water quick. I dont have any cats on it, so maybe that could be leading me in the wrong direction. The carb is a Q-jet, and was rebuilt by Sean Murphy Inc. in california. The car ran amazing a few years ago, so I am sure it is some little thing I am missing. If I tune using a regular O2 sensor, will this put me in the approximate ball park?
Old Sep 9, 2007 | 07:07 PM
chris75stingray's Avatar
chris75stingray
check to see what you plugs look like
Old Sep 10, 2007 | 09:18 AM
lars's Avatar
lars
BigBlockk
Later.....
Old Sep 10, 2007 | 10:22 AM
lr172's Avatar
lr172
How long has it sat? gumming in the carb could lean things up. I would get some seafoam in their to try and clear it up.
Old Sep 10, 2007 | 07:59 PM
St. Jude Donor '09
It sat for about 3 months without being fired up. I am going to try and pull the plugs tonight and see if they give me any indication of where I am at.
Old Sep 10, 2007 | 10:21 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Sep 10, 2007 | 10:50 PM
St. Jude Donor '09
Ok, I pulled the plugs out of it tonight and found that I really need to buy a good digital camera so I can post pictures. Basically what I found was that cylinders 1,3,5,7 look ok, maybe just a tad rich. Cylinders 2&4 look textbook perfect, very slight tan color with the burn spot right in the bend of the ground strap. Cylinders 6&8 however are not so happy. Cylinder 6 has some hardened crud built up around the white part of the electrode and some on the ground strap as well. Cylinder #8 is completly covered in what looks to be hard/wet dark black carbon. I guess its oil because it doesnt smell like fuel. the entire electrode/ground strap are coated in it, no gap in between the strap and electrode at all. Here are the pictures I could take with my phone, they arent very clear but maybe will show some of what I am trying to explain that I see on them. The first two pictures are the #8, next two are #6, and just for reference to what the other plugs look like the last picture is of #2. Also, all my spark plug threads are coated in oil, even the plugs that look fine, what causes this?
Click to make bigger
Old Sep 11, 2007 | 06:00 PM
dannyman's Avatar
dannyman
Oil deposits can be caused by worn valve guide seals. (Cylinder 6/8 check modulator valve for diaphragm rupture/auto transmission.)
If electrodes appear to be destroyed/melting could be pre-ignition typically caused by timing and/or lean fuel mixture.
Install new plugs and see if your misfire is eliminated(this will check cap,rotor and wiring), then troubleshoot further.
Old Sep 11, 2007 | 06:37 PM
St. Jude Donor '09
I would hope its not valve guides as the heads only have 4000 miles on them, I will check the trans diaphram though, I have heard that before where it will foul the back cylinder.
To Afterfiring, tuning, Carb/Timing Gurus?
