Speedo Driven Gear
Sep 10, 2007 | 02:18 PM
Speedo Driven Gear
DOES ANYONE KNOW THE PROPER COLOR AND TOOTH# OF THE DRIVEN GEAR THAT i WOULD NEED FOR 350TH TRANNY AND 3:55 DIFF. GEARS. IT HAD 3:08 IN IT BEFORE.THANX
Sep 10, 2007 | 05:37 PM
just changed mine to the "black" gear and it seems close
i had removed a "natural" from when it had a 3.08 as i also had installed a 3.55
but it still depends on your tire size and speedo
there are a couple of web sites that will give you some guidance
Sep 10, 2007 | 05:39 PM
natural 19 tooth
black 23 tooth
Sep 10, 2007 | 06:06 PM
Sep 10, 2007 | 06:16 PM
Thanx bt and Duke. So it looks like I need the black 40 tooth if i am understanding this right? bt,did you have to put in a different sleeve asm?
Sep 10, 2007 | 06:55 PM
Sep 10, 2007 | 07:24 PM
Quote:
Originally Posted by
76 VETTE
That's the way I read it too.
Sep 10, 2007 | 07:53 PM
no i did a direct swap, the th350 and a muncie use the same small gear set, some members may have some laying around, this website has some good info or you can use keislers site to calculate rpm and speed,
http://chevelleengineer.home.comcast.net/speedo.htm
Sep 10, 2007 | 08:35 PM
