How to bench test gauges
Old Sep 10, 2007 | 03:30 PM
69ttop502's Avatar
69ttop502
Default How to bench test gauges
Looking to bench test some gauges I will be selling. What is the best way to test them all including speedo,tach and all center gauges.
Old Sep 10, 2007 | 03:36 PM
SIXFOOTER's Avatar
SIXFOOTER
Speedo is a mechanical gauge, about the only way to test it is stick it in a car and run it. You can put a cable on it and run it with a drill to see if it functions and the tripmeter works.
Tach, I would hook it up temp on a car, check it out that way
center gauge, ya have to be kind of carefull, Amp meter will smoke if you just hook it up to power and ground. Voltmeter, power and ground is all it needs. Temp gauge, connect it to power, ground and then ground the sender terminal, it should go full scale. Put a 68 ohm resistor to ground and it should go midscale. Oil pressure electrical gauge Power, ground, same test ad temp gauge. Oil Temp, same...
you get the idea
Old Sep 10, 2007 | 06:06 PM
69ttop502's Avatar
69ttop502
Thanks Sixfooter. How about the fuel gauge. I appreciate the info.
Bill
Old Sep 10, 2007 | 07:16 PM
SIXFOOTER's Avatar
SIXFOOTER
Fuel gauge works the same way: Power, ground and a sender line. Ground it and you get full deflection right, open it stays left, bot 50 or 60 ohms should get you mid scale. The fuel sender is 0 to 90 ohms
To How to bench test gauges
