tach drive or HEI?
Old Sep 10, 2007 | 11:12 PM
maddmickey's Avatar
maddmickey
Default tach drive or HEI?
The 74 I bought has an HEI distributor with no tach drive so no tach. I was going to swap a thach head out of a 75-77 but it needs a board. While surfing e-bay I seen tachdrive HEI distributors with cap rotor and the coil for around $140. Has anyone bought one? Are they ok or crap? That seems way cheap. Are there more problems with tachdrive, or HEI tachs? Which way should I go?? Any thoughts are appreciated
Old Sep 10, 2007 | 11:17 PM
PinHead's Avatar
PinHead
I put one of those on my 71' about 9 months ago and have not had any problems. I'm running a stock 350.
Old Sep 11, 2007 | 04:14 AM
Patience's Avatar
Patience
Ditto. I have a similar one, runs perfectly. The only difference between this and the normal HEI is main shaft has an accomodation for a cross-drive gear to run the mechanical tach drive. Otherwise, it's all off-the-shelf HEI stuff, which is pretty bombproof. Furthermore, if you ever need any replacement stuff, you can get it at your local auto parts store.
Old Sep 11, 2007 | 06:28 AM
aussiejohn's Avatar
aussiejohn
Mickey,
I agree with the two P's. I've had one for five years now and it works every time. Only trouble is, I had to modify it to run backwards, as engines go the other way on this side of the equator.
Regards from Down Under
aussiejohn
Old Sep 11, 2007 | 10:07 PM
sperkins's Avatar
sperkins
Forum sponsor Speed City Motors sells them. Mine works good.
http://forums.corvetteforum.com/show....php?t=1629348
Old Sep 11, 2007 | 10:25 PM
guitarcrazy02's Avatar
guitarcrazy02
HEI's the way to go
Had one on my 1975 Camaro for 25 years (my dad put it on before i was even born) and it still kicks but even after the motor buildup I did to it.
Old Sep 11, 2007 | 11:34 PM
dmaaero's Avatar
dmaaero
7000 miles on mine, works great so far.
Old Sep 12, 2007 | 05:48 PM
68/70Vette's Avatar
68/70Vette
I bought a tach drive HEI several years ago from one of the major Corvette vendors (forget who). I think it was over $400. It was probably expensive since it was the first time they were available.
I removed the vacuum advance can, springs and weights, and even the eletronics from the HEI that came with my ZZ4 and installed them in the tach drive HEI. Also, I removed the gear drive from the aftermarket HEI and installed the one that came on the ZZ4 HEI.
Runs fine. Also, the angle that the tach cable mates up to the tach drive HEI is just right. With the tach cable in, the Number 1 and Number 8 distributor contact lugs are perfectly aligned orthogonal to the center line of the car.
Old Sep 12, 2007 | 06:10 PM
jpatrick636's Avatar
jpatrick636
Main Entry: or·thog·o·nal
Function: adjective
Etymology: Middle French, from Latin orthogonius, from Greek orthogOnios, from orth- + gOnia angle -- more at -GON
1 a : intersecting or lying at right angles b : having perpendicular slopes or tangents at the point of intersection <orthogonal curves>
2 : having a sum of products or an integral that is zero or sometimes one under specified conditions: as a of real-valued functions : having the integral of the product of each pair of functions over a specific interval equal to zero b of vectors : having the scalar product equal to zero c of a square matrix : having the sum of products of corresponding elements in any two rows or any two columns equal to one if the rows or columns are the same and equal to zero otherwise : having a transpose with which the product equals the identity matrix
3 of a linear transformation : having a matrix that is orthogonal : preserving length and distance
4 : composed of mutually orthogonal elements <an orthogonal basis of a vector space>
5 : statistically independent
Old Sep 12, 2007 | 06:18 PM
msandym's Avatar
msandym
I bought one. The first one blew up . The company (Star Performance I think) sent a second one. It took a long time , and it was different. Since then , no problem , and my tach works perfect .
Old Sep 12, 2007 | 07:59 PM
72 LT1's Avatar
72 LT1
Also using tach drive HEI from Star Performance. I swapped dist. drive gear from ZZ4's HEI as well. Been 2,000 miles, so far so good.
Old Sep 13, 2007 | 12:57 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I just last week replaced my wore out points style unit with the item you speak of. It cured ALL of my tuning problems on my recently rebuilt 1974 454. I will rebuild the original and keep it just so I still have it. I never realized how much bad effect a sloppy distributor had on an engine.
Old Sep 13, 2007 | 03:10 PM
cal camara's Avatar
cal camara
Default Shielding
Anyone tried to use the original shielding. Will the 75 shilding box cover the HEI unit, I do not believe the 74 and under will work. I know most people leave it off, but I like the look.
cal
Old Sep 15, 2007 | 12:09 PM
carriljc's Avatar
carriljc
Default I've had both....
I have an MSD Tach Drive which I used for several years. When I replaced my engine with a Ramjet 350 I had to decide what to do and I just bought an electric tach from a 75-77. I must say that the electric tach is a lot easier to deal with.
Having said that, that price mentioned for speedcitymotors would be hard to beat. The electric tach that I bought cost me about 60 bucks and then I had to buy the tach card for about 70-80 bucks. While I like having the electric tach a lot better than the mechanical tach, it does involve getting behind the dash...which is quite the pain.
To tach drive or HEI?
