Valve cover bolt help ?
Old Sep 11, 2007 | 07:01 PM
Prestige593's Avatar
Prestige593
Default Valve cover bolt help ?
I have misplaced one of the bolts that secure my original steel valve covers on my L48 stock 350 (1977). I could not find a matching steel bolt, but did find a SS bolt with the same thread. Can I use the SS bolt in the place of the missing bolt? Would there be any problems? Thanks
Old Sep 11, 2007 | 07:31 PM
7T1vette's Avatar
7T1vette
That bolt set is basically "un-stressed". You will have no problem replacing it with a similar SS bolt (other than the head markings won't be the same). [Put it at the back and on the bottom side of a cover so it won't show as clearly.] Make sure you apply the correct bolt torque to them so you don't warp the cover....or it won't seal well.
Old Sep 11, 2007 | 07:49 PM
wnmech's Avatar
wnmech
I have chrome valve covers on my 77 and I have all stainless steel bolts with no problems.
To Valve cover bolt help ?
