What is the range over which the fuel pressure should be for a mild, street 383? Minimum? Maximum?
I thought it should maintain about 6psi but as the car warms up it comtinues to drop to 3 psi after the car is warm. The fuel pressure regulator and fuel pump (electric pump located in the rear) are both brand new as well as all of the filters, etc.
I maintain 6 psi hot or cold and from idle through 6500 rpm. Iwould think 3 psi is getting to be on the low side.
Agreed. But even at 3 psi the car is running fine and rich even (I do need to turn down the idle mixture screws). I just can't figure out what else would cause this.....Started after I overheated the car during a 4th of July parade and ever since I can't maintain a fuel pressure. When the car is cold....6 psi. After it warms up, levels out at 3 psi.
From: Las Vegas - Just stop perpetuating myths please.
Don't use one of those tiny liquid filled fuel press guages inside the eng compart. We found once the eng comp heats up the liquid inside the gauge ruins the reading.
BTW i now use a Holley electric fuel press gauge - only $75 - and its mounted in my clock hole on the instrument panel.
If u use a small gauge inside the eng comp use a "dry" gauge and average the readings as the needle will bounce.
I have: cold engine 8psi and warm 6-7 psi.
3psi means you have something "wrong/broken" somewhere
Hope this helps ya'
cardo0
Actually after a buddy in the club came over to help diagnose the issue we both stood around scratching our heads after checking everything out and he, non-chalantly, says "What if everything is working fine but the gauge is busted?" Turns out that was it. If we put a bag of ice right on the gauge, the reading corrected to exactly what it should have been based on the settings from the electric fuel pump.
