water in a/c system?!?
Old Sep 12, 2007 | 01:14 PM
andylmusic76's Avatar
andylmusic76
Default water in a/c system?!?
so i think there's some kind of liquid like water that was in my eveporator when my friend cleaned it out for me. is there a way to get all this out or does a vaccuum pump take care of it when i vacuum out the whole system? i already used pressure to blow out as much as i could, and i don't even know if there's any in there anymore...
Old Sep 12, 2007 | 01:21 PM
lars's Avatar
lars
Purpose of running the vacuum pump on the system is to evacuate air and moisture. However, if you had water in the system, you should replace the receiver/dryer in addition to running the vacuum pump on the system for a while. If you really want to make sure the system is dry, you can run 1/2-pound-or-so of freon into the system after evacuation and then re-evacuate with the vacuum pump. This will get all the moisture out.
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would just blow it out with shop air. You can't hurt it so use 100 lbs. of pressure or so until moisture stops coming out. I would apply the air to both ends of the evaporator, alternating from one to the other. When it is pumped down with a vacuum pump, I would do so for a couple of hours.
Old Sep 12, 2007 | 01:28 PM
andylmusic76
i already applied 100lbs or pressure on both ends, and i just reinstalled a new drier yesterday. this afternoon i'm gonig to vacuum it out and recharge.
Old Sep 12, 2007 | 01:31 PM
lars's Avatar
lars
Sounds lke you're doing all the right things. Good job!
Old Sep 12, 2007 | 01:42 PM
Jud Chapin's Avatar
Jud Chapin
You da man!
Old Sep 12, 2007 | 02:49 PM
noonie's Avatar
noonie
Besides containing water, that liquid was probably a mixture of oil and water which = acid. Not good for the system.
Buy a can of real A/C system flush and flush the evap. Flush everything except the compressor and a new filter/dryer. At least use laquer thinner until it comes out clean in both directions.
Next put a DEEP vacuum on the system. Normal gauges cannot read this vacuum of 29.92", so if it is a good pump, just leave it on for a long time. You need this deep of a vacuum to suck out the water that turns into vapor at this pressure.
If possible I leave the pump on overnite to make sure all the moisture is out.
To water in a/c system?!?
