383 or LS6??
Old Sep 20, 2007 | 06:46 PM
  #41
Frank_833's Avatar
Frank_833
Originally Posted by Shirley1978
would 210 afr's be overkill?? ...
My 383 has 210 AFR Eliminators. Makes 530hp/505lb. Pretty big cam so power peaks on the high side of 6000rpm, but it makes 400lb of torque from the bottom of the dyno pulls (3500 rpm).
Old Sep 20, 2007 | 09:35 PM
  #42
Frank_833's Avatar
Frank_833
i already have a tko-600 from keisler.. so i dont need a tranny.
If you have a full kit for an SBC, I don't think it won't bolt up to an LS. I beleive input shafts are different. You can get it to work, but would need to swap some parts. I assume Keisler would give you some direction.
Old Sep 21, 2007 | 01:54 PM
  #43
Shirley1978's Avatar
Shirley1978
im assuming for the tranny all i would need to swap would be the flywheel to make it work, maybe some bellhousing adjustments... but other than that i think im good...
so if i go with the carbed ls6, all i would need is a manifold and computer to switch it over to fuel injection right? or am i missing something?
Old Sep 22, 2007 | 01:37 AM
  #44
holley505's Avatar
holley505
http://app.infopia.com/Shop/Control/...d/0/rid/125255
this is all you need... no computer...no distributor... just msd box... and intake manifold... and $50-$100 electric fuel pump to push about 4-6 lbs fuel (enough to feed a CARB) ....it is plug and play...
if you want to get tricky and RUN no2 or other power adder... just switch to a programable MSD box (with laptop) a mer 300 dollars.
http://cgi.ebay.com/ebaymotors/ws/eB...154338511&rd=1
Old Sep 22, 2007 | 11:47 AM
  #45
Shirley1978
well the LS6 im looking at already has an intake mani.. so id just go with the msd box.. what kind of tranny are you running holley??
Old Sep 23, 2007 | 10:52 AM
  #46
holley505's Avatar
holley505
th350 for now.
I purchsed the flywheel and ls1 adapter from hughes about 150 total
