On another site, I've seen spreader bar brackets designed so that the shell of the heim joints is aligned parallel to the ground, rather than perpendicular like most commercial and homebrew spreader bars. Are there any disadvantages to that alignment? It would certainly fit my engine bay better with that alignment, as the heim joints are going to need to be pretty close to the forward a-arm studs.
Ohh I think I get it. Bracket runs perpendicular to the ground whereas the normal bracket runs parallel to the ground along the upper a-arm rod. Never seen what your talking about, the bracket would have to still lay against the pocket or a-arm rod for solid support. I think the other way is easier but i could be wrong.
I'm not talking about the orientation of the bracket. All commercially available brackets (and most homebrew ones) orient the heim joint so that the bolt through the joint eye runs parallel to the ground. I've seen one done so that the bolt runs perpendicular to the ground, which would fit better with my serpentine belt system. I'm just trying to figure out if there are any negatives to orienting the joint in that fashion. Bracket will be a piece of angle iron running parallel to the ground between the a-arm bolts.
I hope that clears up the description.
NO disadvantages....none...long as the support between the two A arm bolts is not twisted from forces applied too low/high....in which case it's not doing it's job....
Gotchya.
Would make access easier for adjustments.
Unless you have a rollcage the frame will twist a little on hard launches so you could get some twisting motion b/w the two A-arms twisting the strut brace.
I'm no expert on heim joints but if you hold your hand like a "V", thumb on one side rest of the fingers on the other. Put a business card or credit card across the gap as if its a strut brace from thumb tip to pointer tip. Now try to close your fingers to eachother and read me your credit card number . That card will bend up applying a force upwards. This is a bit exaderated but much like our front crossmember the A-Arms want to flex towards eachother when the weight of the front end goes down and the A-arms go away from eachother when stomping on the gas. If the force on the strut brace like the card in your hand is going to be verticle then the design of the heim joint with the outside structure on top and down will give you the most strength. If you turn the heim joint on the side like your suggesting then the outside strength is to the front and rear of the car and you loose that verticle strength. See what I'm saying? May not be a big deal unless your car will see alot of abuse.
How often are you going to have to remove the spreader bar for other maintenance or mods? Hardly any. Adjusting the bar is the same wheter it bolted vertically or horizontally; loosen the lock nuts on both sides, turn the bar and retighten the nuts.
Bernie
Bernie
My serpentine pulleys stick out kinda far from the engine, which would put the bolt heads very close to the A-arm studs...just trying to keep some reasonable clearances.
