what cam ?
Old Sep 13, 2007 | 07:26 PM
glo's Avatar
glo
Default what cam ?
Have 383 stroke with.030 flattop piston (2 valve relief )750 holley
headers now the kicker using 882 heaads which have been ported yes I know heads are no good at least thats what I have been told, from what I can figure out I am at thrust hole( compression) for pump gas with these heads have to use these heads for now ( buying house ) .
Cam I have is 224/224@ 50 with 114 lobe also what hp may I be looking at with this setup.As far as what other heads I may get not sure due to my compression ant ideas for heads.
Old Sep 13, 2007 | 10:46 PM
1fastC3's Avatar
1fastC3
what kind of lift are you running, and what kind of intake.
-alex
Old Sep 14, 2007 | 04:25 AM
stingr69's Avatar
stingr69
300 HP or so.
Based on 383, typical headers, muffs, no catalytic converter, dual plane, stock head castings, 9.4 C/R (which is probably not as close to the edge as you suspect), .450"/.460" lift cam and a DD2k simulation.
You could add 50 HP with a head swap to some Dart Iron Eagles.
You could add another 60 HP with a cam swap.
All just stuff I got out of the DD2K. Your results may vary.
-Mark.
Old Sep 14, 2007 | 08:23 AM
Matt Gruber's Avatar
Matt Gruber
since the heads are "ported" i'll guess 375 hp
should be fun to drive and get decent mpg
Old Sep 14, 2007 | 02:01 PM
Cvman74's Avatar
Cvman74
Running a 383 with 9:5 comp..running comp cams magnum 270h..with roller rockers and rpm airgap with demon 750 sportsman 2 heads..dyno at flywheel was 475hp..with of course electric water pump, open headers, electric fuel pump.
Old Sep 15, 2007 | 07:11 AM
tt 383's Avatar
tt 383
i would say for those heads a dual pattern cam would make more power. it would make up for the exhaust sides lack of flow.
To what cam ?
