Breaks
Old Sep 15, 2007 | 12:01 PM
Dryoo7's Avatar
Dryoo7
Default Breaks
I have a rear right (pass) break pack that is shifting when the breaks are applyed. It's like the bolts that hold the calipers to the wheel are worn. I'm looking for Ideas on how to deal with this short of changing the complete caliper; ($) Or perhaps someone might have one in good shape that they would sell. Oh yes, its for a 81 Corvette. Thanks for reading and any help you can offer.
Chuck
Old Sep 15, 2007 | 01:00 PM
sly vette's Avatar
sly vette
Chuck
First take it apart so we know what worn parts we are dealing with.
Spell check...BRAKES!
Mark
Old Sep 15, 2007 | 10:17 PM
chris75stingray's Avatar
chris75stingray
the whole caliper is moving? are the bolts tight?
Old Sep 15, 2007 | 11:45 PM
vette blue's Avatar
vette blue
I'm not sure if it is your pads or your caliper that you are referring to but If you tighten the 2 caliper bolts and they don't grab and tighten then the threads in the trailing arm are stripped. If this is the case you can install Helicoils to fix it. This will keep your caliper from moving.
Old Sep 15, 2007 | 11:52 PM
sly vette's Avatar
sly vette
Aren't the threads in the caliper itself???
Old Sep 16, 2007 | 04:34 AM
RunningMan373's Avatar
RunningMan373
Doonnnnggggg......
akward silence...........
just checked mine,, just holes in the calipers for the rears. (the ones I pulled off last year)
Old Sep 16, 2007 | 02:44 PM
sly vette's Avatar
sly vette
My bad....I just pulled the fronts and I thought I remembered them being the same.
Old Sep 16, 2007 | 03:26 PM
vette blue's Avatar
vette blue
Hi The bolts on the calipers on the rear thread into the trailing arm, but Im still not sure if you are referring to the pads or the caliper moving. Please let us know.
Old Sep 16, 2007 | 08:51 PM
Dryoo7's Avatar
Dryoo7
ok! It sounds like when a u-joint is going. I took it to a shop and had them look at it. Lot of money!! It is the complete brake pack that is shifting. I didn't think to ask if the pack was shifting due to enlarged holes or worn bolts. They said the caliper pack needed repairing. Just seeing if this is something someone knows about and perhaps someone might have one around in good shape they wanted to sell.
Thanks for the help.
Chuck
Old Sep 16, 2007 | 09:07 PM
65GGvert's Avatar
65GGvert
I've never heard the term "brake pack" before. Either the pads are moving or the caliper is moving. If the caliper is moving, either the bolts aren't tightening, or they're the wrong bolts. It sounds like maybe it wasn't assembled correctly. Not enough information to give a conclusive response.
Old Sep 16, 2007 | 11:14 PM
RunningMan373
theres NO SUCH THING AS A "BRAKE PACK". do you mean caliper,, or rear spindle,, and they have to re-PACK the bearings? if you use the right terms people can assist you,, if not,, then not. C.
Old Sep 17, 2007 | 12:36 PM
Dryoo7's Avatar
Dryoo7
I am saying that the caliper AND the pads are shifting as a unit. I'll not be able to answer for a week or so fellas, have to go to the VA in Portland, Oregon for by-pass tomorrow.
Chuck
Old Sep 17, 2007 | 04:09 PM
vette blue's Avatar
vette blue
Ok now we understand that the entire rear caliper is moving.
First try to tighten the the 2 caliper bolts which secure it to the trailing arm.
If they continue to spin and do not tighten the threads are finished and you will need to insert Helicoils.
Make sure you buy the 7/16" - 20thread count Helicoil kit. Do not buy any other kit.
The drill bit has to be 29/64.
Go slowly when tapping and blow out the metal shavings.
More importantly..... best of luck with your bypass and hope you have a speedy and successful recovery so you can get back to fixing that caliper issue.
Old Sep 17, 2007 | 07:17 PM
sly vette's Avatar
sly vette
Good Luck with the surgery!!!
Old Sep 17, 2007 | 08:43 PM
kdf1986's Avatar
kdf1986
Good luck with the surgery. Sounds like that is way more important than the calipers shifting.
kdf
Old Oct 4, 2007 | 06:57 PM
Dryoo7's Avatar
Dryoo7
Thanks for the help guys. It will be a while until I'm under a hood, but I will keep all your input and use it when I can.
Chuck
Old Oct 5, 2007 | 10:06 PM
vette blue's Avatar
vette blue
Hey there. how did the surgery go? Hope all is well.
Old Oct 6, 2007 | 08:23 PM
rainierfarm's Avatar
rainierfarm
what in the heck is a break; can someone tell me ?
Old Oct 7, 2007 | 04:17 PM
Dryoo7's Avatar
Dryoo7
Surgery went ok. This was the third as the veins are bad and they had to put in some fake ones this time. Hope I'm done.
"Breaks" mispelling on my part, bad manners on your part for noticing that my spelling sucks; I'm sorry for my part ..... how bout you?
Chuck
To Breaks
