Cam Specs
Old Nov 10, 2001 | 02:28 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Cam Specs
Thinking of installing a 350ci / 350hp cam in my 77 L48. Anyone else done this? Anyone know the specs on this cam and who makes one?
Old Nov 10, 2001 | 02:34 PM
gearheadz's Avatar
gearheadz
Default Re: Cam Specs (DP77Vette)
This is the original part# for the L-46 cam (350/350). Its an excellent street performance cam and its available through GM Performance Parts:
https://www.spoperformanceparts.com/
Under Smallblock Chevy V8 > Camshafts & Camshaft Kits
3896962 - Hydraulic Flat Tappet
This hydraulic flat tappet is used on the 68-81 L-46 and L-82 Corvette. The duration at lash point in degrees (intake/exhaust) is 312/312; duration at .050" tappet lift (intake/exhaust) is 222/222 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 450/460. Valve lash is zero/zero and lobe centerline is 114 degrees.
Mark
[Modified by mdsmith, 1:38 PM 11/10/2001]
