guys what would you estimate hours put into replacing the under dash harness... including removal of the upper and lower dash pads and replacing the entire dash harness????
Sully,
I would tag each connector as you take the old harness out and then tag the connectors on the new harness. It's really nice to know exactly where everything goes as you put the new harness in. I think the trickiest job is getting the tach/speedo pad back in without pinching something. Good Luck!
Regards,
Alan
