ammeter question
Old Sep 16, 2007 | 10:16 PM
early71's Avatar
early71
Default ammeter question
gauge showing discharge,SLOWLY,WHEN ANY ACC. IS ON.Alternator checked,off car,ok.Lights brighten when engine revs,battery at full strength.Pulled gauge cluster,connnector clean and tight.Any thoughts appreciated.....JC
Old Sep 17, 2007 | 12:00 AM
SIXFOOTER's Avatar
SIXFOOTER
Do you by chance have underdrive pulleys on there? RPM is about the only thing that will affect charging voltage the way you describe. Could maybe be a diode open. That will not necessarily show up on the autozone test, they spin it at normal speed, not idle
Old Sep 17, 2007 | 06:06 PM
Durango_Boy's Avatar
Durango_Boy
, probably a bad diode trio. Look into having it rebuilt if it's a numbers alt. If not, consider upgrading to a CS130 or CS144.
To ammeter question
