Intake recommendation (budget) for L48?
Old Sep 26, 2007 | 05:38 PM
Glensgages's Avatar
Glensgages
billla
you have a Private Message.
Old Sep 26, 2007 | 05:48 PM
column5's Avatar
column5
Originally Posted by billla
Those are all great points - you've done your homework and it sounds like all good choices to me
Thanks! Very reassuring to hear given this is my first foray into "hot rodding."
Old Sep 26, 2007 | 11:31 PM
Tim H's Avatar
Tim H
Since you're looking at $1000 for heads,
Your crazy if you spend $1000 on heads for a street car!!!!
Also on ebay you can get an aluminum intake for $80 shipped ,brand new.
Old Sep 27, 2007 | 04:10 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by column5
One thing that I need (due to the divorced choke on my Q-Jet) is manifold heat. A lot of the heads I have looked at don't have that, but the 60909s do.
Hey Don, just a thought here but you may not want to limit your head decision based on the crossover for the divorced choke.
Electric choke conversions are inexpensive and I also see you live in SW TN so the real cold weather shouldn't be a big factor.
I have a ZZ4 which has what are basically L-98 aluminum Corvette heads. There is no crossover and I still run the divorced choke.
I don't mind sitting with the engine while it's warming up for a minute or so.
Old Sep 27, 2007 | 01:00 PM
Matt Gruber's Avatar
Matt Gruber
bob is on it. heat is bad, except below 32F.
Old Oct 6, 2007 | 06:02 PM
column5's Avatar
column5
She runs again!
Thanks once again to everyone who offered advice on this project. The engine is noticeably stronger now, with a much more aggressive sound.
Much work to be done but it is great to finally have an engine that runs nicely.
Old Oct 6, 2007 | 06:59 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Beautiful car! Congrats on getting it up and running the way you want!
Old Oct 7, 2007 | 11:59 PM
column5's Avatar
column5
Thanks!
One word of caution for anyone reading this...
The Weiand intake is just tall enough to make it impossible to get the Rube Goldberg '74 style air cleaner on with enough hood clearance. The GM Performance Parts air cleaner pictured above fits perfectly and looks 100 times better though! It just needs a '72 LT1-style crankcase vent tube and its good to go, or just use one of the press-in cap-style vents.
Old Oct 8, 2007 | 09:23 AM
Tim H's Avatar
Tim H
Originally Posted by Matt Gruber
if it has stock exhaust, get the summit
turbo mufflers SUM630125 $14.75
best bang for the buck!
(the Qjet is 750 cfm, don't worry about it)
Theres a reason there only $14.75!
Until you go Holley you will always be 1 step behind.
A Q-jet has nowhere near the bottom end take off as a Holley.
But some engines aren't up to par enough to deserve a Holley!
