Disassembling stock power steering pump
Old Sep 18, 2007 | 08:10 PM
68 NJConv 454's Avatar
68 NJConv 454
Default Disassembling stock power steering pump
Trying to take the reservoir off of the pump on a 73/74 stock pump.
How do you do it? What bolts are holding them together?
The ones with the bolt stud?
I see no bolts on the pully side, only the back side.
And can someone point me to a good seal rebuilt kit? that fits right the first time.
Here's what I've got.
Old Sep 18, 2007 | 08:15 PM
David Ey's Avatar
David Ey
Those three hex things....remove them. Do Not bang on the can.
The one on the lower left will have a check valve and spring behind it.. Pat attention to how they come out so you can put them back in correctly.
Old Sep 18, 2007 | 08:58 PM
Maymyvetteliveforevr's Avatar
I agree to remove the 3 at the back. Napa has the correct rebuilt kit. It usually come with about 12 rubber seals and one front metal seal.
Old Sep 18, 2007 | 10:02 PM
SLVRSHRK's Avatar
SLVRSHRK
Here's a link to an article I used to help with my rebuild:
http://www.corvettemagazine.com/2005...ering-lead.asp
It's not hard. Use a digital camera to take pics of each step. That will help when you re-assemble.
Old Sep 19, 2007 | 12:37 AM
68 NJConv 454
Thanks guys. I appreciate the quick responses.
To Disassembling stock power steering pump
