Heat / AC control Vacuum
Old Sep 23, 2007 | 10:46 AM
hgm's Avatar
hgm
Default Heat / AC control Vacuum
No matter which mode or vent I select I get air out of all vents. I have checked the vacuum in a couple of places. At the T inlet in the engine compartment I get 18.6", at the control I am only getting 6.5". I get 0" at the line in the passenger kick panel and at the door in the engine compartment no matter where I have the selector set. I have two questions. 1. Does anyone have any ideas? 2. I purchased a replacement hose kit from Dr Rebuild, how much of the dash do I have to disassemble to install the new hoses? Thanks
Old Sep 23, 2007 | 11:06 AM
SIXFOOTER's Avatar
SIXFOOTER
Center dash and console have to come out and the pass side dash or glovebox and you should be able to get to most of it. Here is a drawing if you don't have it. The vac selector switch is notorious for leaking.
As you can see there is annother T under the dash that could be broken or leaking
