I'm in the midst of a conversion on my 73 454 to a 5 spd set up. Can anyone direct me the the part numbers for a flywheel, flex plate and bell housing?
Don't know the part numbers but you just need a flywheel and bellhousing. No flexplate. they are for automatics. Make sure you get a flywheel that is externally balanced for the 454.
I don't know the part number but they are called a 621 bellhousing for the last digits on the numbers. I am using a blowshield now and put the 621 under the workbench for now.
