Power Window Switch Smoking
Old Sep 26, 2007 | 09:36 PM
attyman1968's Avatar
attyman1968
Default Power Window Switch Smoking
I have an 80 and the passenger window is all the way down. When I hit the switch to roll it back up you can see a very faint glint of smoke coming through the switch. Before I take it apart this weekend, I would like to go ahead tonite and order the parts to fix it. Any idea if its the switch or harness below??? Thanks
Old Sep 26, 2007 | 09:39 PM
kona's Avatar
kona
Probably the switch but you might aswell replace both while you have everything apart.
Kona
Old Sep 26, 2007 | 10:07 PM
...Roger...'s Avatar
...Roger...
Is the window stuck in the door?If so the switch will get hot.See if the glass went down to far and is stuck.
Old Sep 26, 2007 | 10:11 PM
Theiskell's Avatar
Theiskell
Kona
That.... MIGHT ASWELL... will get you every time it has cost me thousands
Old Sep 27, 2007 | 09:32 AM
attyman1968
Not the window. It is free and not in any bind. Tried it this morning.
Old Sep 27, 2007 | 11:02 AM
markdtn's Avatar
markdtn
Could be the window motor is bad, could be the gear is bound up/teeth stripped. I would take to door apart first and make sure everything is good there. In my experience the switches either work or don't, they don't smoke unless there is another problem.
Old Sep 27, 2007 | 11:46 AM
attyman1968
I went home for 30 minutes to meet the cable man, and I took the carpet and seat out so I could get to the switch and connector. Push up on the connector and the window works fine. Let it get a little wiggle between the switch and connector, then I got smoke. The switch just doesn't seem to hold tight to the connector.
Old Sep 27, 2007 | 12:48 PM
markdtn's Avatar
markdtn
I stand corrected then. Switch is much easier and cheaper than a motor or gear.
Old Sep 27, 2007 | 03:00 PM
7T1vette's Avatar
7T1vette
Chances are that the switch contacts are about shot. That will increase resistance in the switch and cause more heat. Replace BOTH switches while you are in there....the other is as old (and probably almost as worn) as the one giving you trouble.
Old Sep 27, 2007 | 03:27 PM
attyman1968
Actually, both switches are only about 13 months old. The entire interior including all guages, switches, etc was gutted last year and replaced, but that switch always seemed to have a clicking problem in which it felt like it never made good contact. I plugged the connector to the other switch about an hour ago and everthing worked fine, so now I am sure its just a faulty switch. Its no big deal other than waiting on a switch to get here. I am planning on taking this car and my 1960 to Cruisin the Coast in Biloxi next week, and both seem to be giving me some electrical trouble. Always happens right before you get ready to go somewhere.
Old Sep 27, 2007 | 09:53 PM
markdtn's Avatar
markdtn
Haven't checked in a while, but at 1 time that switch was available from the HELP section at the parts stores.
To Power Window Switch Smoking
