My '74 goes off to the left a bit, need to always correct it. We swapped front wheels, still the same, tires are new. I work for a Jeep dealer and the tech's don't want to touch the Vette...One of the guys said it would require "shims" to do the alignment...Any thoughts on what to do and/or what type of shop would do the work?
Thanks in advance,
Kevin
kmobrien76@yahoo . c o m
Reason: name missing
Yes it would reqire shims to do the alignment. Dont know why you Jeep tech doesnt want to do it, its same principle as doing most front ends. Although arent all jeeps 4-wheel drive w solid axel? That may be why.
Caster, camber and toe are set to factory specs first. if all thats right, then there is an adjustable valve on the power steering assist piston that pushes the center link right to left. I never adjusted mine, but from what i hear, there is a small cover w an adjustment screw that you cane use to center the steering pump pressure. I dont think i would even touch that until i know the front end geometry is right first. (caster/camber/toe) Otherwise you will be using that as a crutch for possible caster that may be off.
We do our own alignment because we have the tools for the race car, but its smart to take it to a reputible shop in your area that has experience w vetts. The rear needs to be aligned as well. Do you have a GM service manual? Specs are there. If not, i can fax you a copy.
Thanks in advance,
Kevin
My 1970 BB had the same problem, always wanted to go off to the left a bit. I had the front end aligned at a local Pontiac shop yesterday and the left front Camber was off quite a bit. The mechanic corrected this, and also brought the front toe in into specs. Now the car steers straight with no problems. The Corvette is just a standard GM front end of that era, and any good shop can do it for you. While you are at it, go ahead and have them check the rear alignment and correct it if needed.
From: San Diego - Deep Within The State of CONFUSION!
The front end is the same standard-issue control arm suspension that GM used for decades, before Rack & Pinion. Two unequal length control arms with the spring & shock between them, and a paralellagram for steering linkage. The C3 was no different in any of this stuff.
Any ALIGNMENT SHOP should be able to do this alignment. Also: how old are your control arm bushings? When they get old and wear unevenly, the control arms shift & this can cause caster to change. The caster change is what causes a car to drift to one side; it will always go to the side with the least amount of caster.
