Preparing a 400 ci bloc
Old Oct 6, 2007 | 05:38 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Shouldn't have a problem with holes as long as you are aware half of them have to go in at a 40 degree angle
Old Oct 6, 2007 | 05:43 PM
Durango_Boy's Avatar
Durango_Boy
, good point, that never gets mentioned.
Old Oct 6, 2007 | 09:11 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by I'm Batman
Go for it...I'm sure we all would like a detailed tech report on how long cylinder heads with no steam holes last on a 400SBC.
Originally Posted by Durango_boy
Hose them how? The material you're drilling through is not that thick and it's an open cavity under the hole. Mark the spot with a punch, drill a small pilot hole and then follow with a 1/8" bit. It went super easy when I drilled my two heads for my 400. I just don't see how drilling the hole would harm them.
You try it. I'm not gonna blow up a set of heads for an experiment.
Originally Posted by 427V8
Not drilling the steam holes is a bad idea. Drilling them isn't that hard.
Well the Rodeck aluminum engine block i have has no steam holes.
What do you guys suggest i do......pull an iron block out of a caprice and use that?
Old Oct 6, 2007 | 10:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Obviously your aftermarket block is a different story. If the block does have steam holes, and you don't drill them in the heads, you're asking for trouble.
Old Oct 7, 2007 | 12:41 PM
turtlevette
Am i asking for trouble by having a block with no steam holes.?
You're saying my block is no good.?
Let's follow the logic through here. Good practice for your bar exam.
Old Oct 7, 2007 | 01:18 PM
Durango_Boy
What he's saying is that after market block of yours was designed without steam holes so you don't need them in either the block or the heads. However, if your block was NOT after market and had steam holes then it's dangerous to install heads without steam holes.
There are just too many people with cracked blocks and heads because this little precaution is missed or avoided because they don't think it's necessary.
Old Oct 7, 2007 | 01:38 PM
turtlevette
Do you have any links that support this.?
Steam holes are unnecessary.
I think i'm gonna stand firm on that and let you guys prove me wrong. Real proof, not just do it because that's how it came from the factory.
Can someone come up with a scientific argument?
Can someone come up with experience that proves the holes are necessary.?
I get sick of hearing the same old **** being propagated over and over and over when nobody really understands it.
Old Oct 7, 2007 | 01:46 PM
Durango_Boy
http://www.gregsengine.com/350to400.htm
http://www.chevyhiperformance.com/te...que/index.html
(Fifth paragraph down.)
http://answers.yahoo.com/question/in...5105436AAbqQRq
Just a few. You seem to be the only one who refuses to believe. I don't even understand you fighting on this one. What do you gain by telling people not to drill steam holes when it may inevitably lead to a cracked head. Maybe because it's not your motor and if they have to replace a cylinder head it's no skin off of your back?
Old Oct 7, 2007 | 02:01 PM
turtlevette
read carefully. The holes are what are causing the heads to crack.
Its like drilling a brake rotor.
Old Oct 7, 2007 | 02:49 PM
nicoduc's Avatar
nicoduc
Eh, turtlevette, your engine is already in your car or you are restoring it?
What are your engine specs : standard or ..?
Old Oct 7, 2007 | 03:11 PM
SteveG75's Avatar
SteveG75
From the AFR website:
http://www.airflowresearch.com/sbc_faq.php#400blocks
4) 400 BLOCKS:
Steam holes are recommended for all 400 block applications (GM blocks only). Use a 400 Gasket as a template and drill the three holes, nearest the spark plug side of the head, straight down. The other three which are very near the head bolt holes should be drilled at a 30° angle away from the bolt hole. The center hole will intersect water about 1" down and the two outboard holes to a depth of 2 1/4". Use 1/8 drill.
A Rodeck block is NOT a GM block. Different water passages, different rules. This is like comparing apples to bananas.
Old Oct 7, 2007 | 03:35 PM
enkeivette's Avatar
enkeivette
If you're not on a tight budget, you might want to consider using a 350 block with a 3.875" stroke crank. This will yield 396ci... almost 400 but without the siamesed cylinder bores, better cooling.
Old Oct 7, 2007 | 03:49 PM
  #33
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Nothing wrong with the cooling on a 400, if everything is functioning properly.
Old Oct 7, 2007 | 05:32 PM
  #34
Edzred72's Avatar
Edzred72
Just my $.02..
GM casting 817 block is 2 bolt main. Very good solid block.
GM casting 509 block is two bolt main high nickel content. The numbers010 and 020 are cast into the face. "The best GM 400 block!"
GM casting 511 block is 4-bolt (majority). Not as strong as the 2 bolt cause that fourth bolt weakens the webbing between cylinders....but 500HP is safely obtainable.
Pick a cam bigger than you think, cause most cam co's stats are for a 350. (unless stated for 400ci) 350 RPM ranges will actually be lower when it's used in a 400. Roller cams are great if you can afford one. My Crower is as quiet as a church mouse.
I agree with 200-210 heads on a 400. Mine run great!!! (AFR 195 Eliminators are the exception)
Flat top pistons in the 10.0 to 10.5 compression range for a mild sub 240 durration cam. No detonation worries...
Stock 400 rotating assemblies are externally ballanced. If your purchasing a new one...go internally ballanced throughout. Pistons, rods, crank, ballancer, & flywheel must be ballanced together for optimum results. 500HP is obtainable without a forged crank, (should be a good one though) but if you plan to beat on that engine regularly at the strip...go forged crank. Forged pistons & rods are the norm for a 500 HP build. Better safe than sorry. I would not use hyperutectic pistons on a high horse motor. On a cruiser...yes...but not a strip motor.
Well...the choices are yours.
Good Luck
Eddie
