Differential Question
Old Sep 28, 2007 | 11:02 PM
OddBall's Avatar
OddBall
Default Differential Question
Checked all the differential posts that I could find, but I couldn't find any info on the torque specs for the diff cover bolts.
Mine is a '78, with a 3.08 rear end, 6 cover bolts.
For that matter, where can dig up a good set of torque specs on the car?
BTW, great differential posts! learned a lot. ('cept for the torque on the cover bolts )
Old Sep 28, 2007 | 11:10 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
From the Chevy 1978 chassis service manual, Rear Axle, 4B-21...
Carrier cover, 50 ft lbs.
Filler Plug, 20.
Pinion lock screw, 20.
Bearing caps, 55.
Ring gear bolts, 55.
The factory SM is indispensable.
Old Sep 28, 2007 | 11:15 PM
OddBall's Avatar
OddBall
THANKS!
( gonna get me that manual )
Old Sep 28, 2007 | 11:26 PM
TheSkunkWorks
They can cost you a bit thru some of the typical Vette vendors, but you may find a bargain on fleaBay...
For whatever reason, the '78 book is an all inclusive Chevy book, so a lot of guys get the '79.
To Differential Question
