push rods
Old Sep 29, 2007 | 04:00 AM
Gumby86's Avatar
Gumby86
Default push rods
Any suggestions on what kind of push rods to use for these heads? Thanks.
DRT-10121111
Brand: Dart
Product Line: Dart Iron Eagle Cylinder Heads
Part Type: Cylinder Heads
Cylinder Head Style: Assembled
Cylinder Head Material: Cast iron
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 64
CNC Machined Combustion Chamber: No
Intake Runner Volume (cc): 180cc
Exhaust Runner Volume (cc): 75cc
CNC Machined Intake Runner: No
CNC Machined Exhaust Runner: No
Combustion Chamber Style: Heart
Intake Port Location: Standard
Exhaust Port Shape: Square
Exhaust Port Location: Standard
Spark Plug Style: Straight
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.020 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.600 in.
Valve Springs Included: Yes
Maximum Valve Lift (in): 0.520 in.
Outside Diameter of Outer Spring (in): 1.250 in.
Damper Spring Included: No
Number of Springs Per Valve: Single
Retainers Included: Yes
Retainer Material: Steel
Locks Included: Yes
Lock Style: 7 degree
Valve Stem Seals Included: Yes
Valve Stem Seal Style: PC seal
Rocker Arm Studs Included: No
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: Yes
Guideplate Pushrod Size: 5/16 in.
Valve Cover Mounting Style: Center and perimeter bolt
Accessory Bolt Holes Drilled: Yes
Intake Valve Angle: 23
Exhaust Valve Angle: 23
Valve Guides Included: Yes
Valve Guide Material: Manganese bronze intake/Phosphorous bronze exhaust
Valve Seats Machined: Yes
Valve Seat Machine Style: 4-angle intake/3-angle exhaust
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: No
Old Sep 29, 2007 | 04:37 AM
gingerbreadman1977's Avatar
gingerbreadman1977
thats way too much information on heads to find out what push rods to use. just get a push rod measuring tool is the best way . im assuming your using roller rockers so get some bearing blue and be sure to get the roller rolling equally and as near as possible to the centre of where it seats for the right geometry.you will have to wind the motor over a few times and adjust the rod to get it right but it is crutial you do it.
Old Sep 29, 2007 | 06:10 AM
stingr69's Avatar
stingr69
http://www.sdparts.com/product/12495...ushrodKit.aspx
I would start with these. If they are the right length, run them. I just picked up a set. You can also get these +.100" if needed for the same price. You ain't gonna beat the price or value.
-Mark.
To push rods
