wrong radio
Old Sep 29, 2007 | 11:11 PM
babylonvette's Avatar
babylonvette
Default wrong radio
i have a 72 coupe project that i am putting together and am trying to get everthing in car working i bought a corvette radio 72/76 sterio? it has 6 wires coming out and my sterio box has 9 wire round plug is it adaptable or do i have a later radio can it be wired in or should i try to buy correct radio?
Old Sep 30, 2007 | 02:41 AM
RunningMan373's Avatar
RunningMan373
Pictures needed. do you have the amp in the car,,or pulled also?
Old Sep 30, 2007 | 03:55 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
It seems the radio you got has the stereo amps built inside the it, as all the '74-'77 radios are, so basically you can just omit the stereo box and connect the right and left speakers directly to the radio.
Old Sep 30, 2007 | 07:54 AM
babylonvette
thanks for the reply i will try that, it is definatly the easy route to go ,that way i can just plug and play, i wiil stop by my local corvette dealer and see if he can help out with the numbers that are on the unit,appreciate the help ,artie
To wrong radio
