X-pipe location
Old Sep 30, 2007 | 08:39 AM
Belgian1979vette's Avatar
Belgian1979vette
Default X-pipe location
I would like to know what the best location would be for an X-pipe on a C3.
Old Sep 30, 2007 | 09:27 AM
Roughrider's Avatar
Roughrider
Supposedly the way to find the best place for a crossover or X-pipe on any exhaust system is to take a crayon or grease pencil, and run a line from the flange to the muffler. Then start the engine and let it warm up to operating temperature. After shutting the car off, look to where the line you drew has disappeared. At the spot where it again becomes visible is where you install the crossover or X.
I don't know the theory or physics behind it, but it's what a car magazine several years ago reported in a test of crossover and x-pipes exhausts...if you believe what a car mag writes.
Old Sep 30, 2007 | 09:47 AM
jim2527's Avatar
jim2527
Old Sep 30, 2007 | 09:58 AM
panic's Avatar
panic
You have to compromise beetwin what's the best and what's the best 'posible' place where to fix the X pipe, my humile opinion is just after the crossmember...
Old Sep 30, 2007 | 12:14 PM
Belgian1979vette
That was my idea to panic. What size pipes are that ?
Old Sep 30, 2007 | 12:48 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
And where did you pick up the X pipe from? I think I will add one when I am finishing up the LS exhaust when the time comes.
Old Sep 30, 2007 | 04:05 PM
panic's Avatar
panic
the whole exhaust is 2 3/4' and the X pipe alone is 3'...
Old Sep 30, 2007 | 04:09 PM
panic's Avatar
panic
here you go...it's the 3'' dia from jeg's..
http://www.jegs.com/webapp/wcs/store...55652_-1_11525
To X-pipe location
