454 Flat Top Piston Dots
Old Oct 1, 2007 | 01:31 PM
mikem350's Avatar
mikem350
Default 454 Flat Top Piston Dots
Rebuilding my '73 454, and found the stock bore flat tops (GM) have the dots facing right (all 8). I know somebody has gone thru the motor before
The rods have their numbers facing out in their correct holes. I just want to re-ring and let 'er go. Put the pistons back in same way???
What is correct??
Thanks, Mike
Old Oct 1, 2007 | 01:58 PM
454_71Stingray's Avatar
454_71Stingray
The dot should be on the side towards the front of the engine if I remember my rebuild accurately.
Old Oct 1, 2007 | 02:19 PM
mikem350's Avatar
mikem350
Thanks, but
Dots front on small blocks...BB is side to side
Old Oct 1, 2007 | 11:16 PM
mikem350's Avatar
mikem350
ttt
Old Oct 2, 2007 | 12:40 AM
Little Mouse's Avatar
Little Mouse
big blocks pistons are all RIGHTS. With the rod/piston in your hand and the
grooves for the rod bearings facing the outside of the block the piston will have the exhaust notch on the left the intake notch to the right. as long as you mount the pistons on all eight rods with the intake valve notch to the right, your good to go. then put all eight in with the bearing holding grooves facing the out side of the block, when you look at every hole of your big block the intake valve notch of the piston will be to the right.
Old Oct 2, 2007 | 03:19 PM
mikem350's Avatar
mikem350
Thanks a million, Just the info I needed!!!
This Forum is the best
To 454 Flat Top Piston Dots
