Dewitts rad install problem
You should have minimum 1/2" between the sway bar and the outlet.
No reason to play with it.
To adjust, loosen all 6 core support screws,
loosen the 2 large bolts on the side of the angle that bolts to the front crash bar/vacuum resevoir.
Using wood cut to fit, carefully jack up the core support so that you have clearance at the rad outlet. You don't want it to touch.
Retighten all bolts. This could possibly raise the whole front end (fiberglass) a half inch and at the firewall a negligeable amount.
The whole front end literally hangs on that assembly and just sags after so many years. Have done it this way to several cars.
Wow man, great info. Thanks so much.
I will run that by my mechanic tonight. thanks for your help. I had the rad support out and painted. maybe on reinstallation it has sat lower than it was originally?
if all else fails i think i will have to go with the plate spacer option, but i will try the support adjustment first. from what i remember on reinstallation it was all pretty tight and seemed to go back exactly where it was.
will post findings later on
tried to adjust the rad support but it is so tight there is hardly no movement at all. looks as though i will have to make up some spacers.
just got the charge wire and fan wiring to go
Neal
If you can't get enough adjustment from the 2 big bolts in the angles under the vacuum tube, then loosen the tube mounting points on the frame horns on each side (2 brackets each side) and jack up the tube and retighten. It doesn't take much to free up space for the lower rad outlet. Watch your shroud and fan clearance.
A good body man is better than a regular maechanic in most cases.
all your help is appreciated guys thanks
