squeaking noise from the back
Old Oct 3, 2007 | 10:08 PM
gabriel911's Avatar
gabriel911
Cruising
Default squeaking noise from the back
i recently replaced the mono spring and it lifted the rear end up a couple of inches. Ever since then i have had a loud squeaking noise coming from the rear, only happens when i let off the gas, as soon as i hit the gas again the noise goes away...someone told me that it might be the universals, but I'm not sure, and ideas???
BTW it is on a 79...
Old Oct 4, 2007 | 12:09 AM
pbcanney's Avatar
pbcanney
That'd be my wag as well
They are working at a different tragectory now if it's 2 inches higher..
got a grease gun? do the ujoints have grease fittings?
Old Oct 5, 2007 | 01:34 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
I know it may be A shot in the dark but here goes . My shaft on my shocks would make A similar noise I sprayed em with light oil and the noise went away . spray some lube at the frame where the Control arms blot to the frame. good luck I hate Squeekes.
Old Oct 5, 2007 | 02:53 PM
Artsvette73's Avatar
Artsvette73
This happened to me also. If you know the u joints are good try it.
To squeaking noise from the back
