Is there a diagram someone could post that shows all the vacum hose routing for the wiper system. I have a hose that is not connected and suspect that's why my wiper compartment does not open.
Thanks!!!
The only difference on the early cars there is only one headlight relay valve with y-connectors feeding the headlights instead of the two used in later years.
The hose routing in the above link diagram is wrong.I briefly read some of the explanations and quickly found the headlight switch explanation to be backwards.Vacuum to the small hose on the relays make the lights go down - "not up" as the explanation says.I didnt bother to read further to see if the wipers were correct.
Below is an accurate diagram from Dr. Rebuild for the wipers
