Too much play in steering column...
Old Oct 4, 2007 | 11:06 AM
Vetteitbe87's Avatar
Vetteitbe87
Default Too much play in steering column...
I have an 81' and there is a little too much play in the steering than I like. I think its just in the column because the steering feels tight. There is about an in. of play on both sides before the steering is actually effected. Is there any way to tighten this up without removing the column?? I just want tight handling! Thanks
Austin
Old Oct 4, 2007 | 12:18 PM
Fuelie74's Avatar
Fuelie74
I think what you are feeling is not in the steering coulmn, but in steering box. You can adjust the steering box gear backlash to take care of that problem. I remember seeing some good posts on that in hear. Try running a search.
Old Oct 4, 2007 | 01:59 PM
Theiskell's Avatar
Theiskell
check out some of Jim Shea's posts. He is the steering expert lots of help with him
Old Oct 4, 2007 | 02:04 PM
Durango_Boy's Avatar
Durango_Boy
Austin
I would advise against adjusting it yourself unless you have the proper tools to do it right. If you over adjust even just a little bit you will compound the problem may damage the internals.
It would be best to first consult Jim or Gary, GTR1999, about your options.
The best idea, if your box is sloppy, would be to ship it off and have it rebuilt or ship it off as a core and buy a new rebuilt box from one of these builders.
Old Oct 4, 2007 | 02:28 PM
texbeasr3's Avatar
texbeasr3
Make sure your rag joint is in good condition. If you see marks on the stop or any movement, then a new coupling might be in your future.
Old Oct 4, 2007 | 04:17 PM
Fuelie74's Avatar
Fuelie74
For the price of having someone else do it you can buy the tools if you don't already have them and follow a service manual. Its not that bad of a job and a good learning expereance.
Old Oct 5, 2007 | 12:35 AM
Vetteitbe87
Sounds good, ya steering systems aernt my forte. I will check out some of the posts and hopefully its just something I can manage myself. Thanks guys!
Old Oct 5, 2007 | 02:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Check the rag joint first. When it starts to go, it makes for a very sloppy feel in the steering system.
Old Oct 5, 2007 | 03:00 AM
agent kronus's Avatar
agent kronus
I have the same problem, both my rag joint and steering have too much play!
dave
Old Oct 5, 2007 | 06:15 AM
Jim Shea's Avatar
Jim Shea
The only Chevrolet sanctioned methods of adjusting the Corvette manual gear are either to remove the gear from the car and use an inch-lb torque wrench or a procedure where the gear is left in the car but you remove the pitman arm from the gear and use a torque wrench on the steering wheel nut.
I know that I will suffer the rath of Gary (GTR1999) but the engineers at Saginaw were able to adjust the steering gears by feel within acceptable levels with the gear in the car. You have to be careful and follow the procedure exactly. But it will get you into the ballpark and can lead you to the exact cause of your looseness in the steering system.
Here is a link to the paper that I authored on the in-car method.
http://jimshea.corvettefaq.com/wp-co...-Rev25JA06.doc
Jim
Old Oct 5, 2007 | 07:04 AM
silver 76's Avatar
silver 76
I was quite suprised how bad my rag joint was on my 74 it helped but the final fix was to replace the P. S. control valve.
To Too much play in steering column...
