power windows
Old Oct 4, 2007 | 05:33 PM
1975corvette's Avatar
1975corvette
Default power windows
Hi Guys
I have a small problem with my power windows
1975 Vette
They are very slow does anyone have a cure
Old Oct 4, 2007 | 05:37 PM
Durango_Boy's Avatar
Durango_Boy
Are they both the same speed? Did both of them slow down from a faster pace?
I would think system voltage drop if both of them exhibit the same symptom.
Old Oct 4, 2007 | 05:55 PM
1975corvette
yes they both slowed down at the same time
Could it be a bad ground ????
Old Oct 4, 2007 | 06:04 PM
Durango_Boy
Possible. Maybe someone with a '76 AIM can check out the window motor wiring and see if there is a common ground or separate grounds for each motor.
If it's separate grounds then I doubt that's the problem. It might be a corroded power wire.
How is the system voltage? Battery in good shape with no corrosion or faulty connections? How's the alternator's output?
Old Oct 4, 2007 | 06:15 PM
mrvette's Avatar
mrvette
You can check the voltage at the relay or the switches...and then across the motor, but I bet it's the load dragging the motor assy down and not the electrics....
winter is coming, chilly weather up north...and so the grease in the door tracks seizes up and the wheels don't roll/slide too great....
I afraid what you need to do is take it ALL apart, glass outta the naked door, and get those tracks outta there, get a nice large concrete mixing tray from Home Despot/other...and load it with 2 gallons of gasoline to soak those tracks overnight then you can get a wire or natural fiber brush to clean them up squeeky clean.....that damn old dried out grease is a killer....when you put them back together use NO LUBE OF ANY KIND.....if the nylong rollers are bad, obviously they need changing.....Dr. Rebuild for starters, there are other suppliers...
I degreased my tracks 12 years ago, and the windows work like a guillotine since then....
grease the motors/shafts/gearbox....obviously....but NOT the tracks...
Old Oct 4, 2007 | 07:09 PM
1975corvette
Gene
I have not checked the voltage
The gauge barely moves when I lower the windows
the problem has been ongoing for several months
yes the cold weather is coming however we do not live
at the north pole
its still 75 degrees no frost on the pumpkins yet if you know what I'm saying
LOL
and my Car is kept in a heated garage
Old Oct 4, 2007 | 07:10 PM
1975corvette
Durango
Now battery new Alt. new cables all in 2007
Old Oct 4, 2007 | 07:38 PM
chris75stingray's Avatar
chris75stingray
are they slow when the car is running? i think that would rule out the voltage drop. probably dried up grease, or the motors going bad?
Old Oct 4, 2007 | 08:06 PM
SIXFOOTER's Avatar
SIXFOOTER
the fact that they are 32 yrs old might have something to do with it. The tracks get gummed up and the rollers wear and the connectors might drop a little voltage here and there. All that together will make them run slow. I would take 1 door apart at a time, clean the tracks Real well, relube them and put them back together. You might need new rollers, they are cheap. Look over the connectors real well, there are more splices in there than you would believe. Clean ans crimp the connectors to make sure they make good contact, use a little no-ox to stop/prevent corrosion.
They will run like new
Old Oct 4, 2007 | 08:17 PM
1975corvette
Thanks Guys
awesome feedback
food for taught
A few things to try come winter (January)
Old Oct 4, 2007 | 08:28 PM
jdp6000's Avatar
jdp6000
Thanks Guys
awesome feedback
food for taught
Are they slow going up or down? Or both. If its just up its likely the regulator spring. Either weak or broken. If its broken you will find it at the bottom of the door. Cheap to buy but a little work to replace.
Jim
Old Oct 4, 2007 | 09:04 PM
tjhuyser's Avatar
tjhuyser
also don't forget the felt..it drys out and wears inside the tracks that gives it extra play and the window ***** in the track and drags down..
Old Oct 4, 2007 | 09:15 PM
elevatordude's Avatar
elevatordude
You might want to ohm out the relay contacts if the contact is worn from the arcing you will get a voltage drop to the moters
Old Oct 4, 2007 | 09:19 PM
croaker's Avatar
croaker
Maybe 32 year old swithes mine are acting the same I've got new switches just don't want to tear into them
Old Oct 5, 2007 | 08:50 AM
jdp6000's Avatar
jdp6000
Don't throw the old ones out. I bought new but they were not as good as the old. You can carfully pry the tabs on the old....open them up....bend the copper slider back into place and use for another 20 years.
Jim
Old Oct 5, 2007 | 09:05 AM
RAGTOP75's Avatar
RAGTOP75
SIXFOOTER is spot on. I have the same problem with my '75. This Wisconsin winter I;m going to remove the windows and replace the rollers etc. The way I found out that it was old grease was by hosing WD-40 into the tracks and roller area. After leaving it soak over nite the windows worked much better. Old grease and several owners later, it's time for the disassembly and rebuild.
To power windows
