New Carb in 77 with original engine
Old Oct 4, 2007 | 07:31 PM
yoitslikejohn's Avatar
yoitslikejohn
Default New Carb in 77 with original engine
A quick question from a first timer. My new edelbrock carb has an electric choke. Where is a safe power source for the electronic choke?
Old Oct 4, 2007 | 08:32 PM
Durango_Boy's Avatar
Durango_Boy
Anything IGN or ACC. On my '77 fuse panel I have a spot for a tap labeled ACC which means it's only on when the key is on. I used that for a fuse panel triggered by a relay so I have multiple IGN leads.
An easier tap is the yellow wire from the wiper motor wiring. It's an IGN only wire that's easy to get to and close to the carb.
Use that one to start.
Old Oct 4, 2007 | 08:52 PM
Bob Onit's Avatar
Bob Onit
Which direction is ACC with the key?
I had always considered it to be with the key turned back towards the driver, which would not be my first choice for an electric choke.
The choke source should only be hot when the key is turned to IGN.
I used the wiper circuit on my '73 as well but they only work with the key turned forward to IGN.
Old Oct 4, 2007 | 08:57 PM
tjhuyser's Avatar
tjhuyser
I'm Confused!!!..Shouldn't the power flow through a temp sending unit to vary the voltage to open and close the choke??
Old Oct 4, 2007 | 09:02 PM
Bob Onit's Avatar
Bob Onit
No, the spring in the choke reacts to the current from the 12V supply.
Old Oct 4, 2007 | 09:21 PM
dannyman's Avatar
dannyman
You need constant power at the choke otherwise it would close.
Old Oct 4, 2007 | 09:56 PM
vette blue's Avatar
vette blue
ACC is recommended and when the key is turned toward ignition it will provide power to the electric choke. www.edelbrock.com has a website that includes a video on the choke install and carb install check it out. Good luck.
Old Oct 4, 2007 | 10:08 PM
Durango_Boy
As mentioned above, ACC is also the same position as IGN when the key is rotated forward. However, you can power ACC circuits ONLY by rotating the key backwards without turning on IGN circuits.
Basically there are two ways to power the ACC circuits and one way to power IGN circuits.
Old Oct 5, 2007 | 12:05 AM
Glassbowtie77's Avatar
Glassbowtie77
I just had my Q-Jet converted to electric choke, I wired it to the ACC plug on the fuse panel and works fine.
Old Oct 5, 2007 | 09:13 AM
lars's Avatar
lars
Pull the power to the choke from the wiper motor - it goes hot any time the ignition is "on" or in "acc" position. Do not take paower off of the hot wire to the coil or distributor.
Lars
Old Oct 5, 2007 | 09:16 AM
pbcanney's Avatar
pbcanney
Well, I too lirnt sumpthin new today
I thought it was a variable voltage signal
To New Carb in 77 with original engine
