1979 corvette speedo ?
Old Oct 4, 2007 | 06:03 PM
nomocrap's Avatar
nomocrap
Default 1979 corvette speedo ?
I have a wide ratio warner 4 spd. The speedo gear inside the trans turns freely with trans is in gear. From the trans diagrams this gear should lock on the main shaft. With the trans out of the car how hard would this be to change? Where would I get this gear? Also if the other speedo gear is a 18 tooth what rear axel ratio would I have? Thanks for any help
