Plugs and Plug wires
Old Oct 5, 2007 | 12:53 PM
KennyZush's Avatar
KennyZush
Default Plugs and Plug wires
Hello,
Got my first vette a few months ago...
1977 L48
I am getting ready to do some much needed maintenance.
Just wanted to check in with a quick question:
What plugs and wires to you folks prefer?
Thanks for any input.
Kenny Z.
Old Oct 5, 2007 | 01:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like to go with original equipment, Delco.
Old Oct 5, 2007 | 01:32 PM
stingr69's Avatar
stingr69
Delco stock replacement wires and Autolite plugs
-Mark.
Old Oct 5, 2007 | 01:34 PM
lars's Avatar
lars
Old Oct 6, 2007 | 08:36 AM
KennyZush's Avatar
KennyZush
Well...looks unanimous.
Thanks for the advice.
Kenny Z.
Old Oct 6, 2007 | 08:51 AM
jim2527's Avatar
jim2527
Kenny,
Regardless of what you read on the forum, you DO NOT need to remove or unbolt the motor mounts to install the front 2 wires on each side.
Lub up the distributor boots with dielectric grease. Slide the 'boots' of the wire being carefull not to damage the wires. Slide the distrubtor end through the top of the motor mount.
Take pictures of the factory routing when you dis-assemble. Its complex.
Old Oct 6, 2007 | 12:45 PM
dc502's Avatar
dc502
I did mine that way.
Old Oct 6, 2007 | 03:58 PM
KennyZush's Avatar
KennyZush
Originally Posted by jim2527
Kenny,
Thanks for the tip...
I know the wires are not stock or run from the factory, but I will note their placement.
Kenny Z.
Old Oct 6, 2007 | 05:29 PM
Jud Chapin's Avatar
Jud Chapin
Unfortunately, I didn't. But now I know better!
To Plugs and Plug wires
