dizy in wrong?
Old Oct 9, 2007 | 06:01 PM
  #41
Bob Onit's Avatar
Bob Onit
Originally Posted by agent kronus
its the vac thing I'm trying to solve now!!
cheers
dave
Dave, Where did you hook up the vacuum gauge?
When you installed the Air-Gap did you use gaskets on the front and rear of the block or did you use RTV silicone?
Old Oct 9, 2007 | 06:23 PM
  #42
agent kronus's Avatar
agent kronus
the full intake manifold vac pipe on the carb, at the bottom coming out at a angle on the holley 750
I used rtv silicone for the sides
cheers
dave
Old Oct 9, 2007 | 07:30 PM
  #43
Oldguard 7's Avatar
Oldguard 7
Sounds like a reliable source for a manifold vacuum reading. Does your vacuum guage have any colored areas or writing on it which indicate a condition such as late ignition timing, weak valve springs, a normal range area, etc. Btw what year is your vette and what mods have you made to your engine. Please take some time and fill out your profile because that will help other members identify your model year or similair mods on their vehicles making it easier to help with your issues.
cheers, mate
Old Oct 9, 2007 | 09:48 PM
  #44
SmokinBBC's Avatar
SmokinBBC
I played with dizzy, got the thing started, got the timing gun on it, sorted, set at 8 degrees intial timing, it does seem a bit lumpy, but my battery is dead, maybe that might cause it to be a bit funny!
got a vac gauge on it, still slows a low reading 11/12 hg, which was the same as before, defo no vac leaks, maybe worn valves causing low vac or different cam??
Still need to tune carb, which I will do soon
cheers
dave
Dave..check out this site for Vacuum readings...scroll down to the green buttons to get an example of the problem and possible diagnosis.
http://www.secondchancegarage.com/public/186.cfm
Old Oct 9, 2007 | 10:47 PM
  #45
Oldguard 7's Avatar
Oldguard 7
I like that. I'm going to put it on my favorites page.
Old Oct 10, 2007 | 02:14 PM
  #46
agent kronus
cheers, mate
done the profile mate, my vac gauge just has numbers on it, it reads about 11/12 hg, there is a "little need shake", on the vac gauge website below, says that is sign of cams overlaping, ie performance cams
cheers
dave
  #47
agent kronus
great website
cheers
dave
Old Oct 10, 2007 | 08:02 PM
  #48
SmokinBBC's Avatar
SmokinBBC
great website
cheers
dave
One of the better 'how to read' with examples that I have found...
