guide plates
Old Oct 7, 2007 | 01:47 AM
Gumby86's Avatar
Gumby86
Default guide plates
What should I torque the guide plate studs down to on my heads?
Old Oct 7, 2007 | 09:35 AM
stingr69's Avatar
stingr69
After you have the head installed on the block and you have aligned the rocker arm tips/pushrods with the valve stems you will want to put some sealant on the rocker arm threads and torque the studs down to 50 Ft-Lbs.
-Mark.
Old Oct 7, 2007 | 10:44 AM
Durango_Boy's Avatar
Durango_Boy
Make sure you're using hardened push rods. Soft stock ones are more likely to wear against the plates and leave metal shavings in your oil.
To guide plates
