Rivetts how to install
Old Oct 8, 2007 | 01:09 PM
ktmdon's Avatar
ktmdon
Default Rivetts how to install
I'm progressing on my 73 vert and know must replace some rotted metal brackets underneath. Not shure how to properly install solid rivetts. Can anyone give some guidance ?
Old Oct 8, 2007 | 01:32 PM
LYLE's Avatar
LYLE
To get the squash to look right the rivet should be cut off so 1/8 inch is used to peen over. Hold a heavy piece of metal on the head and tap on the outside of the rivet to form a round squash with a small ballpeen hammer. The rivets are soft so you will learn quick. Some use a muffler air tool with a drilled hole like the squash in a old tool that is cutoff and drilled.
Old Oct 8, 2007 | 03:08 PM
chuck d's Avatar
chuck d
I changed the plates you mentioned a number of years ago. I used aircraft rivets and drove them with the the appropriate rivet set and gun (air hammer). You can use a bucking bar or big hammer to form the upset head.
To Rivetts how to install
