Steering Control Valve Question.
Old Oct 9, 2007 | 07:41 PM
cboyd's Avatar
cboyd
Default Steering Control Valve Question.
Hey Guys
Just finished rebuilding my SCV as per Jim Shea's paper, no problems, excellent paper. When I had the CV installed on the frame, (body still off) and turned the steering I noticed a little play, maybe 3/16" side to side at C/V ball & socket. I know there is a spring in the ball and socket side, is this what's causing the play? During assembly, when I tightened the plug into the ball/socket sleeve, I would have had to pull really hard on the tool to get the slots in in the plug to line up with the slots in the sleeve and I really had to force on the ball to get it to move in the socket, so as per the paper I loosened it until the next slot lined up. The ball was still stiff but not binding.
Note: There are still no P/S lines hooked up as it is a body off resto.
I just wanted to check if this play is normal, before I pull the thing apart again.
Clyde
Old Oct 10, 2007 | 01:54 AM
wombvette's Avatar
wombvette
Originally Posted by cboyd
Hey Guys
Clyde
This question is probably asked about a hundred times a year. The play is normal.
Old Oct 10, 2007 | 06:05 AM
cboyd's Avatar
cboyd
Thanks wombvette
Really appreciate the reply, saves me a lot of work.
Clyde
To Steering Control Valve Question.
