Tach problems
Old Oct 10, 2007 | 06:01 PM
'Bochawa72's Avatar
'Bochawa72
Default Tach problems
I didn't turn up much in my search, some helpful tips but nothing specific so here goes. My mechanical tach cable broke. The end that fits into the back of the tach was so twisted up it looked like it had been machined. It was twisted perfectly. Anyway, that cable was not moving very freely in the housing at all. I got a new cable and it is very free but after hooking it up to the tach I can't turn it by hand at all. I seem to remember it turning very freely by hand before. Is it time to get the guage itself rebuilt? Perhaps something I might be able to do myself? Thanks.
-CR
Old Oct 10, 2007 | 06:29 PM
Z-man's Avatar
Z-man
It should twist freely and you should see the tach rise.
You could probably rebuild it depending on how handy you are. If you send the tach out to be rebuilt, a human somewhere will be repairing it.
Old Oct 10, 2007 | 06:46 PM
shafrs3's Avatar
shafrs3
If the engine in your avatar is one you've installed yourself a tach should be no problem, the biggest PITB is getting the dash out.
Old Oct 10, 2007 | 07:56 PM
'Bochawa72's Avatar
'Bochawa72
Yeah, I did the install myself. And no the cable does not twist freely. My speedo guage is a bit jumpy as well, just as the tach cable was before it decided it had had enough. Might as well get em both. Winter project I suppose. I looked in a couple of catalogs and didn't find a rebuild kit. Does such a thing exist or is it as easy as going in and cleaning everything up? Thanks guys!
-CR
Old Oct 10, 2007 | 09:38 PM
gldnkngt's Avatar
gldnkngt
-CR
Sounds to me like your tach is binding up a bit. There are a number of things that could cause that. It probably wouldn't hurt, (other than taking the tach and speedo out-ouch) to have it looked at by a gauge guy.
Old Oct 10, 2007 | 09:40 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Corvette Clocks by Roger. Jackson TN.
Old Oct 11, 2007 | 12:04 AM
Z-man's Avatar
Z-man
You might try a small drop of 3-in-1 oil on a toothpick in case it's just a matter of lubrication...
To Tach problems
