Common Corvette Fire Hazards
Old Oct 11, 2007 | 02:02 PM
okinawa86vette's Avatar
okinawa86vette
Default Common Corvette Fire Hazards
Since this is what everyone wants to talk about, here's your legitimate chance to talk on topic about it.
I'll start it off......
Wiring: A failed ignition wire burned up in my '88 coupe and took most of the dash harness and some other pieces with it.
Chris
Old Oct 11, 2007 | 02:20 PM
rihwoods's Avatar
rihwoods
http://www.nfpa.org/assets/images///...rstignited.jpg
Old Oct 11, 2007 | 02:33 PM
Durango_Boy's Avatar
Durango_Boy
I can tell you talking on a cell phone while fueling up your car is NOT a fire hazard unless you're cell phone is on fire or mimicking a 4th of July sparkler.
Old Oct 11, 2007 | 02:59 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Timing adjustment resulted in carb backfire, which resulted in fire in carb, which resulted in fire burning the Vette to the ground in minutes.
Old Oct 11, 2007 | 03:30 PM
eastltd's Avatar
eastltd
Chris
I had one of those foam "bug eye" air cleaners catch fire in my Nova but since it was a Nova and not a Vette it doesn't count in this post.
I also had old wiring in the steering column of my 56 Chevy catch fire but that don't count either.
I have a frient that knows someone who has a friend the burnt his car up with bad stereo wiring too.
These are all off topic so I'lll stop now. Sorry Dude, I'm just messing around. Please don't take offence. You had a legitimate beef with your last post. Somebody check my spellling.
Old Oct 11, 2007 | 03:41 PM
wjsullivan's Avatar
wjsullivan
Headlight control **** shorted out and started a small dash fire.
Old Oct 11, 2007 | 03:46 PM
68 NJConv 454's Avatar
68 NJConv 454
Fire is my biggest fear now that i've put all this time and money into this car. The only thing not replaced is the wiring harnesses b/c they're so freakin expensive. I could have convinced myself to spend the money if it was an upgraded wire harness that can handle much more power and todays modern convieniences made by a company like Painless but i didn't find such a product. So now I'm spending my money on fire extinuishers and church to pray.
Old Oct 11, 2007 | 04:01 PM
js292's Avatar
js292
Not the Vette, but I had a old Firebird that the positive cable shorted out in the trunk and started a fire. Glad I had a extinguisher to put it out
Old Oct 11, 2007 | 04:26 PM
okinawa86vette
Some of you guys are killing me. Glad you guys picked up on the point I'm making.
I think the reason your not supposed to talk on the cell phone while pumping gas is because you may not pay attention if the auto shutoff doesn't work.
This actually happened as I pulled my car up to the gas station just last week. Some lady was in her car chatting away while gas spewed out overflowing from her tank. For whatever reason, the auto shut off didn't work right.
C
Old Oct 11, 2007 | 04:28 PM
crf311's Avatar
crf311
Electrical fire or Gas leak has to be up at the top
Old Oct 11, 2007 | 05:28 PM
Jay-Dog's Avatar
Jay-Dog
Headlight switch. I decided NOT to buy a 77 vette when I noticed that the speedo area was discolored and slightly melted. They guy proceeded to tell me how he put out a litlle fire there once. Then he bragged about how he fixed it by installing a battery shut off which he flips every time he uses the car. Nice fix buddy, and NO, I'm not interested in buying your POS.
Old Oct 11, 2007 | 05:56 PM
Glensgages's Avatar
Glensgages
..... ignition problem on the burn-out:
broken connecting-rod, exiting the engine:
Old Oct 11, 2007 | 07:13 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
This is the result of using an improper fuel line. This was a 1969 427 435 Hp car with a rubber fuel line feeding the tripower from the inline filter. A crack in the fuel line or a bad clamp will spew gas at 7 PSI and a gallon per minute until it ignites. Once it ignites and you realize it, pull over and shut it off there is so much fuel and vapor in the engine compartment a fire extinguisher might not save it. Use only proper fuel lines, fittings and filters.
Old Oct 11, 2007 | 07:27 PM
okinawa86vette
That's crazy....almost looks like something out of a movie....
Old Oct 11, 2007 | 07:57 PM
Tim H's Avatar
Tim H
I noticed you are talking about one of those "bug eye air cleaners" and was wanting to know if you knew the height from the carb to the top?
Old Oct 11, 2007 | 08:00 PM
GTR1999's Avatar
GTR1999
You're dead on. I don't know how many cars I see at cruise nights with rubber lines and glass inline filters all over the place. Build a steel line with metal or aluminum inline filters with AN fittings.
Saw a 69 coupe that burned up RR quarter panel after hose pinched the caliper and heated up enough to catch it on fire.
Old Oct 11, 2007 | 08:12 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Wow, those air cleaners are a fire hazard? I never knew that! Thank God the kind and intelligent people on this forum have posted this important info, because I was going to ask what the height was as well!! There is no way I will put one of those on my car now!
For the love of sweet Jesus, don't tell me those glass fuel filters are a fire hazard as well?!?!?! I better go out and remove mine right away!!
To Common Corvette Fire Hazards
Old Oct 11, 2007 | 08:27 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
little molotov cocktails ...
Old Oct 11, 2007 | 08:35 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Actually, my 75 caught on fire when the hood insulation fell down a bit and rested on the exhaust manifold.
Old Oct 11, 2007 | 08:49 PM
Matt O's Avatar
Matt O
Chris
I had a pinhole leak develope in the metal fuel filter on the right side of the engine on my 69 vert. Driving along and I smell gasoline everywhere. Stopped and opened the hood and this thing was spraying raw fuel on the engine. For the record I have no idea why the damn thing didn't go up in flames!
